11.03.2022, 14:51
Good morning,
I\'m writing to you because I need assistance with the widgets in the mosaic.
I need a widget that only indicates the value of the associated object.
In this case it\'s a valve, and I need a widget in the mosaic that tells me if the valve is open or closed.
I found a widget that tells me the current value of the object but only for a few seconds when the value changes its state. It\'s called Value (text) in CUSTOM WIDGET EDITOR.
Not good, because I need to know the status of the tubes at any time.
