event start part of the script
I try to find out how i can trigger a part of a script.
i think i need to use event.dst.
I add tags on the groupsobject who trigger the script.
The script have multiple part what to do.
If the script is trigger by 1/1/1 i will just run the first part of a script.
if it is trigger by 1/1/2 i just run the second part of the script.
i think i need to use event.dst and elseif, but don't know how to use it.
Somebody who can help me with this?
if event.dst == '1/1/1' then
-- do something
elseif event.dst == '1/1/2' then
-- do something
elseif event.dst == '1/1/3' then
-- do something
-- do something when nothing matches event.dst
Thank you Erwin,
is it also posible to use this if '1/1/1' = false?
and when 1/1/1 is between 0 and 50
Or can we only use it when it is true?
Replace — do something with:
if event.getvalue() == false then
— do something
or
value = event.getvalue()
if value >= 0 and value <= 50 then
— do something
Thank you Erwin, i will try this.
