Trend Logs (Max, Min Average)
Hi, is it possible to get the Max, Min and Average values ( all stored data) from each trend name so that they can be added to vis.
Trend Logs
1) Power DB1 : max 2/3/10 min 2/4/10 average 2/5/10
2) Power DB2 : max 3/3/10 min 3/4/10 average 3/5/10
3) Power DB3 : max 4/3/10 min 4/4/10 average 4/5/10
4) Lighting DB1 : max 5/3/10 min 5/4/10 average 5/5/10
This example will calculate min/max/average for the past year data. Keep in mind that this is rather CPU and memory intensive calculation so it's not recommended to run it too often.
require('trends') trends.NaN = 0 / 0 dates = {} dates['start'] = os.date('*t') dates['start'].year = dates['start'].year - 1 dates['end'] = os.date('*t') values = trends.fetch('TREND_NAME_HERE', dates) min, max, sum, cnt = math.huge, -math.huge, 0, 0 for _, value in ipairs(values) do   if value == value then     min = math.min(min, value)     max = math.max(max, value)     sum = sum + value     cnt = cnt + 1   end end avg = sum / math.max(1, cnt) log(min, max, avg)
(09.05.2022, 08:11)admin Wrote: This example will calculate min/max/average for the past year data. Keep in mind that this is rather CPU and memory intensive calculation so it's not recommended to run it too often.
Thank you once again.
