Please, I hope you could help me in my issue
However, I was trying to get the weather infomation from apixu.com and write them on the KNX bus.
I just followed the exemple on the openrb.com this one (https://openrb.com/featch-weather-forecast-from-apixu), I only changed the key variable as it's mentioned in the exemple.
-- temperature in C
grp.write('32/1/1', current.temp_c)
-- "feels like" temperature in C
grp.write('32/1/2', current.feelslike_c)
-- humidity as percentage
grp.write('32/1/3', current.humidity)
-- wind speed in kilometers per hour
grp.write('32/1/4', current.wind_kph)
-- uv index
grp.write('32/1/5', current.uv)
-- weather condition text
grp.write('32/1/6', current.condition.text)
-- pressure in millibars
grp.write('32/1/7', current.pressure_mb)
-- precipitation amount in millimeters
grp.write('32/1/8', current.precip_mm)
-- minimum temperature in celsius for the day
grp.write('32/2/1', today.mintemp_c)
-- maximum temperature in celsius for the day
grp.write('32/2/2', today.maxtemp_c)
-- average temperature in celsius for the day
grp.write('32/2/3', today.avgtemp_c)
-- average humidity as percentage
grp.write('32/2/4', today.avghumidity)
-- maximum wind speed in kilometers per hour
grp.write('32/2/5', today.maxwind_kph)
-- uv index
grp.write('32/2/6', today.uv)
grp.write('32/2/7', today.condition.text)
-- total precipitation in millimeters
grp.write('32/2/8', today.totalprecip_mm)
grp.write('32/3/1', tomorrow.mintemp_c)
grp.write('32/3/2', tomorrow.maxtemp_c)
grp.write('32/3/3', tomorrow.avgtemp_c)
grp.write('32/3/4', tomorrow.avghumidity)
grp.write('32/3/5', tomorrow.maxwind_kph)
-- uv index
grp.write('32/3/6', tomorrow.uv)
grp.write('32/3/7', tomorrow.condition.text)
grp.write('32/3/8', tomorrow.totalprecip_mm)
No data was found on those groupe addresses,
Or if you could give me any other solution, I only wants to write 1 on the KNX bus if there's a snow tomorrow, the place is Bergen in Norway
yr.no provides free detailed forecast API.
This example will check if there will be snow in the next day. You only need to adjust your location (latitude/longitude) and the status object address. There might be some limits on how often the API can be accessed so create a scheduled script that runs every 3 hours or so.
latitude = 60.3894
longitude = 5.33
status = '1/1/1'
1 "# #"
2 "# IMPORTANT - PLEASE UPDATE YOUR API ENDPOINT #"
3 "# #"
4 "# This API endpoint is deprecated and has now been shut down. To keep using the apixu API, please update your integration #"
5 "# to use the new weatherstack API endpoint, designed as a simple drop-in replacement. #"
6 "# You will be required to create an account at https://weatherstack.com and obtain an API access key. #"
7 "# #"
8 "# For more information on how to upgrade please visit our Github Tutorial at: https://github.com/apilayer/weatherstack#readme #"
9 "# #"
a "#################################################################################################################################"
The free tier in weatherstack does not provide forecast data, only current conditions. Consider using yr.no instead. We will publish an updated integration script for yr.no next week.
-- Please comment objects which you are not using, comment also grp.write() at the bottom of script
--latitude = 60.3894 -- Bergen
--longitude = 5.33 -- Bergen
latitude = 56.9496 -- Riga
longitude = 24.1052 -- Riga
--latitude = 51.5072 -- London
--longitude = 0.1276 -- London
status_temp = '32/1/13' -- group address of temperature, should be float
status_pressure = '32/1/14' -- air pressure, should be float
status_humidity = '32/1/15' -- relative humidity, should be float
status_wind_direction = '32/1/16' -- wind direction, should be float
status_wind_speed = '32/1/17' -- wind speed, should be float
status_uv_index = '32/2/4' -- UV index, should be float
status_feelslike_temp = '32/2/3' -- feels like temperature, should be float
status_rain_today = '32/1/11' -- today's rain object, should be boolean
status_snow_today = '32/1/12' -- today's snow object, should be boolean
status_min_temp_today = '32/1/20' -- today's minimum air temperature, float
status_max_temp_today = '32/1/21' -- today's maximum air temperature, float
status_min_pressure_today = '32/1/22' -- minimum air pressure, float
status_max_pressure_today = '32/1/23' -- maximum air pressure, float
status_min_wind_speed_today = '32/1/24' -- minimum wind speed, float
status_max_wind_speed_today = '32/1/25' -- maximum wind speed, float
status_min_uv_today = '32/2/5' -- minimum UV today, float
status_max_uv_today = '32/2/6' -- maximum UV today, float
rain_tod_YR = false -- is rainy or not (for today)
snow_tod_YR = false -- is snowy or not (for today)
rain_tom_YR = false -- is rainy or not (for tomorrow)
snow_tom_YR = false -- is snowy or not (for tomorrow)
-- current temperature, air pressure, humidity, wind direction and speed
temperature_YR = -273 -- temperature in degree Celsius
air_pressure_YR = -1 -- air pressure in hPa
humidity_YR = -1 -- air humidity in %
wind_direction_YR = -1 -- wind direction in degrees [0; 360)
wind_speed_YR = -1 -- wind speed in m/s
uv_index_YR = -1 -- UV index
feelslike_temp_YR = -273 -- feels like temperature in degree Celsius
function init_min_max_table() -- initialize table for minimum, maximum temperature, pressure, windspeed
local min_max = {}
min_max.min_t = 8000 -- minimum temperature for today
min_max.max_t = -273 -- maximum temperature for today
min_max.min_p = 8000 -- minimum pressure for today
min_max.max_p = -1 -- maximum pressure for today
min_max.min_w = 8000 -- minimum wind speed for today
min_max.max_w = -1 -- maximum wind speed for today
min_max.min_uv = 8000 -- minimum UV index
min_max.max_uv = -1 -- maximum UV index
return min_max
function set_timestamp(day) -- if day = 0 today; if day = 1 tomorrow, if day = 2 day after tomorrow
local date = os.date('*t')
date.day = date.day + day
local time = os.time(date)
return os.date('%Y-%m-%d', time), date.hour -- timestamp and current hour
-- minimum maximum values of temperature, pressure and windspeed
function min_max_temp_press_wind(dat_tab, min_max_tab)
min_max_tab.min_t = math.min(min_max_tab.min_t, dat_tab.air_temperature or 8000)
min_max_tab.max_t = math.max(min_max_tab.max_t, dat_tab.air_temperature or -273)
min_max_tab.min_p = math.min(min_max_tab.min_p, dat_tab.air_pressure_at_sea_level or 8000)
min_max_tab.max_p = math.max(min_max_tab.max_p, dat_tab.air_pressure_at_sea_level or -1)
min_max_tab.min_w = math.min(min_max_tab.min_w, dat_tab.wind_speed or 8000)
min_max_tab.max_w = math.max(min_max_tab.max_w, dat_tab.wind_speed or -1)
min_max_tab.min_uv = math.min(min_max_tab.min_uv, dat_tab.ultraviolet_index_clear_sky or 8000)
min_max_tab.max_uv = math.max(min_max_tab.max_uv, dat_tab.ultraviolet_index_clear_sky or -1)
return min_max_tab
function check_for_rain(next1h)
local is_rainy = false
local code = ''
if type(next1h) == 'table' and type(next1h.summary) == 'table' then
code = next1h.summary.symbol_code or ''
if code:find('rain') then
is_rainy = true
return is_rainy
function check_for_snow(next1h)
local is_snowy = false
local code = ''
if code:find('snow') then
is_snowy = true
return is_snowy
function calc_heat_index(temperature, humidity)
if temperature < 26.7 then
log('for heat_index calculation temperature should be higher than +26.7 Celsius degree')
return -273
if humidity < 0 or humidity > 100 then
log('humidity should be in a range from 0 ... 100%')
return -273
local T = temperature
local H = humidity
local c_1 = -8.785
local c_2 = 1.611
local c_3 = 2.339
local c_4 = -0.146
local c_5 = -0.0123
local c_6 = -0.0164
local c_7 = 0.00221
local c_8 = 0.000725
local c_9 = -0.00000358
local heat_index = c_1+c_2*T+c_3*H+c_4*T*H+c_5*T*T+c_6*H*H+c_7*T*T*H+c_8*T*H*H+c_9*T*T*H*H
return heat_index
function calc_wind_chill(temperature, wind_speed)
if temperature > 10 then
log('temperature should be less than +10.0 Celsius degree')
return -273
if wind_speed < 0 or wind_speed > 49.2 then
log('wind speed should be in a range 0 ... 49.2 m/s')
return -273
local T_air = temperature -- air temperature Celsius degree
local a = 0.62 -- coef
local b = 0.51 -- coef
local T_1 = 13.1 -- Celsius degree
local T_2 = 14.6 -- Celsius degree
local M_0 = 1.3333 -- m/s
local M = wind_speed -- m/s
local T_wind_chill
if M > M_0 then
T_wind_chill = (a*T_air + T_1) + (b*T_air - T_2)*(M/M_0)^0.16
T_wind_chill = T_air
return T_wind_chill
function calc_feelslike(temperature, wind_speed, humidity)
local T_feelslike
if temperature <= 10.0 then -- if less than 10.0 Celsius degree (or equal) then wind chill
T_feelslike = calc_wind_chill(temperature, wind_speed)
elseif temperature >= 26.7 then -- if more than 26.7 Celsius degree (or equal) then heat index
T_feelslike = calc_heat_index(temperature, humidity)
else -- other cases just return temperature
T_feelslike = temperature
return T_feelslike
min_max_today = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction
min_max_tomor = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction
mac = 0
io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)
mac = mac * 256 + tonumber(v, 16)
end)
http.USERAGENT = 'LM ' .. mac
res, err = http.request(url)
data = json.pdecode(res)
if type(data) == 'table' then
timestamp, hour = set_timestamp(0) -- current day
if hour < 10 then
timestamp_current_hour = timestamp .. 'T0' .. hour .. ':00:00Z' -- time stamp for current hour
timestamp_current_hour = timestamp .. 'T' .. hour .. ':00:00Z' -- time stamp for current hour
--timestamp_after_next = set_timestamp(2) -- timestamp for day after tomorrow
--log('timestamp_after_next = ' .. timestamp_after_next)
--timestamp_after_after = set_timestamp(3) -- timestamp for day after day after tomorrow
--log('timestamp_after_after = ' .. timestamp_after_after)
for i, entry in ipairs(data.properties.timeseries) do
-- for weather now
if entry.time == timestamp_current_hour then -- get data only for one hour (current hour)
current_data = entry.data.instant.details
if type(current_data) == 'table' then
temperature_YR = current_data.air_temperature or -273 -- temperature in Celsius degree
air_pressure_YR = current_data.air_pressure_at_sea_level or -1 -- air pressure in hPa
humidity_YR = current_data.relative_humidity or -1 -- air humidity in %
wind_direction_YR = current_data.wind_from_direction or -1 -- wind direction in degrees [0;360)
wind_speed_YR = current_data.wind_speed or -1 -- wind speed in m/s
uv_index_YR = current_data.ultraviolet_index_clear_sky or -1 -- uv index
feelslike_temp_YR = calc_feelslike(temperature_YR, wind_speed_YR, humidity_YR) -- feels like temperature in Celsius degree
if entry.time:sub(1, #timestamp) == timestamp then -- checks remaining hours + 3 previous hours of current day
min_max_today = min_max_temp_press_wind(current_data, min_max_today)
if rain_tod_YR == false then -- if detected rain does not check for rain
rain_tod_YR = check_for_rain(entry.data.next_1_hours)
if snow_tod_YR == false then -- if detected snow does not check for snow
snow_tod_YR = check_for_snow(entry.data.next_1_hours)
if entry.time:sub(1, #timestamp_next) == timestamp_next then -- checks 24 hours of next day
tomor_data = entry.data.instant.details
if type(tomor_data) == 'table' then
min_max_tomor = min_max_temp_press_wind(tomor_data, min_max_tomor)
if rain_tom_YR == false then -- if detected rain does not check for rain
rain_tom_YR = check_for_rain(entry.data.next_1_hours)
if snow_tom_YR == false then -- if detected snow does not check for snow
snow_tom_YR = check_for_snow(entry.data.next_1_hours)
-- data for current hour
grp.write(status_temp, temperature_YR)
grp.write(status_pressure, air_pressure_YR)
grp.write(status_humidity, humidity_YR)
grp.write(status_wind_direction, wind_direction_YR)
grp.write(status_wind_speed, wind_speed_YR)
grp.write(status_uv_index, uv_index_YR)
grp.write(status_feelslike_temp, feelslike_temp_YR)
-- data for today: rain, snow; min and max for temperature, pressure, wind
grp.write(status_rain_today, rain_tod_YR)
grp.write(status_snow_today, snow_tod_YR)
-- data for tomorrow: rain, snow; min and max for temperature, pressure, wind
grp.write(status_rain_tomor, rain_tom_YR)
grp.write(status_snow_tomor, snow_tom_YR)
09.06.2022, 08:21 (This post was last modified: 09.06.2022, 08:27 by AlexLV.)
Hi, super job is done!. Will test it in nearest time.
Some ideas for improvements/additional possibilities:
1. If weather info is needed for place where device is located - possible not to show coordinates directly in script but take them from system:
require('uci')
latitude = uci.get('genohm-scada.core.latitude')
latitude = tonumber(latitude) or 0
longitude = uci.get('genohm-scada.core.longitude')
longitude = tonumber(longitude) or 0
If 0 - no coordinates - should be entered than..;
2. Would be great if we can show group addresses for weather conditions in the beginning of script, because these groups will be created later in this script (addresses showed natively, not by names). I see it was planned to do so, but was commented.. For me groups 33/1/XX are used, For test I will manually change them in script;
3. In my existing weather script I use weather condition icons. So condition is taken from informer, than condition's icon is showed at visu...
May be ''symbol code'' info from yr.no we can add to script and use with icons?
4. how often we can start this script? Once a day? Some informers not allowed very often requests and can block them, or allows for additional payment..
10.06.2022, 07:53 (This post was last modified: 10.06.2022, 08:11 by RomansP.)
The updated version of weather script.
1.) Added possibility to read coordinates (latitude and longitude) from system.
2.) Changed data types of objects:
a.) for humidity dt.scale
b.) for uv_index dt.uint8
c.) for pressure dt.uint16
-- You can set latitude and longitude in "Date time" option
-- go to LogicMachine->Utilities->Date and time
require('uci')
latitude = uci.get('genohm-scada.core.latitude') -- read latitude from system
longitude = uci.get('genohm-scada.core.longitude') -- read longitude from system
if(latitude == 0 and longitude == 0) then -- if cooridinates were not set in the system
-- you can set latitude and longitude manualy
-- (if you set coordinates using "Date time" do not forget to comment these two lines
local min_max = {}
return min_max
return min_max_tab
local code = ''
is_rainy = true
return is_rainy
local code = ''
is_snowy = true
return is_snowy
return -273
return -273
local H = humidity
local c_1 = -8.785
local c_2 = 1.611
local c_3 = 2.339
local c_4 = -0.146
local c_5 = -0.0123
local c_6 = -0.0164
local c_7 = 0.00221
return heat_index
return -273
return -273
local T_wind_chill
if M > M_0 then
return T_wind_chill
local T_feelslike
return T_feelslike
mac = 0
end)
if hour < 10 then
-- for weather now
22.06.2022, 08:17 (This post was last modified: 22.06.2022, 08:57 by RomansP.)
Hi, Mrinj!
Yes it is still working for me. Can you attach your script, so I will try to figure out what could gone wrong.
The updated version for script.
Added check for http.request , so there will be a log if something gone wrong.
res, code = http.request(url)
if res and code == 200 then
log('request error', res, code)
require('uci')
local min_max = {}
return min_max
return min_max_tab
local code = ''
is_rainy = true
return is_rainy
local code = ''
is_snowy = true
return is_snowy
return -273
return -273
local H = humidity
local c_1 = -8.785
local c_2 = 1.611
local c_3 = 2.339
local c_4 = -0.146
local c_5 = -0.0123
local c_6 = -0.0164
local c_7 = 0.00221
return heat_index
return -273
return -273
local T_wind_chill
if M > M_0 then
return T_wind_chill
local T_feelslike
return T_feelslike
mac = 0
end)
if hour < 10 then
-- for weather now
As sad earlier, from your script I only change the addresses to 53/1/* from your script cause my 33/*/* once are busy
Script is attached.
Thanks!
Mrinj
RomansPHi, Mrinj!
require('uci')
local min_max = {}
return min_max
return min_max_tab
local code = ''
is_rainy = true
return is_rainy
local code = ''
is_snowy = true
return is_snowy
return -273
return -273
local H = humidity
local c_1 = -8.785
local c_2 = 1.611
local c_3 = 2.339
local c_4 = -0.146
local c_5 = -0.0123
local c_6 = -0.0164
local c_7 = 0.00221
return heat_index
return -273
return -273
local T_wind_chill
if M > M_0 then
return T_wind_chill
local T_feelslike
return T_feelslike
mac = 0
end)
if hour < 10 then
-- for weather now
However, Until now i had script work fine , but now i cant obtain weather dates,
This is the scheduled script that I used.
I can see on log :
* arg: 1
* string: <html>
<head><title>400 The plain HTTP request was sent to HTTPS port</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
<center>The plain HTTP request was sent to HTTPS port</center>
<hr><center>nginx/1.18.0 (Ubuntu)</center>
</body>
</html>
Thaks a lot!!
If I use the script above , I have no data , I receive :
table:
[data]
* table:
[next_6_hours]
* table:
[summary]
* table:
nesting too deep
[details]
* table:
nesting too deep
[next_12_hours]
* table:
[summary]
* table:
nesting too deep
[next_1_hours]
* table:
[summary]
* table:
nesting too deep
local min_max = {}
return min_max
return min_max_tab
local code = ''
is_rainy = true
return is_rainy
local code = ''
is_snowy = true
return is_snowy
return -273
return -273
local H = humidity
local c_1 = -8.785
local c_2 = 1.611
local c_3 = 2.339
local c_4 = -0.146
local c_5 = -0.0123
local c_6 = -0.0164
local c_7 = 0.00221
return heat_index
return -273
return -273
local T_wind_chill
if M > M_0 then
return T_wind_chill
local T_feelslike
return T_feelslike
data = json.pdecode(table.concat(response))
if hour < 10 then
-- for weather now
