Reading trends from RRD in Lua
#21
Hello everyone
is it possible to have a CSV file with all curves with this method?
For sure but you must change a script because there are 2 things:
1) how connect 2 trends with different resolution
2) be aware about the size of generated .csv (because of email limits and because of LM CPU power and memory)
This is why I'm not created the script for doing all trends in one .csv.
I think that better is create such script which generate all trends one by one with some pause between each email. And then you have all scripts and e.g. you can connect them via excel(if they are not too big) or via nodejs script or some windows program for such things.
Done is better than perfect
(29.08.2018, 08:49)buuuudzik Wrote: For sure but you must change a script because there are 2 things:
Indeed the CPU can be used too much.
After making a backup there is no possibility to recover all of this data in a file?
I would like to retrieve all the data on 65 curves (same resolution) for 6 months ... it's really a lot by mail
Thank you for Reply.
I've updated a trends_pro library to allow simple modifying its data and adding more calculated column.
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118119120121122123124125126127128129130131132133134135136137138139140141142143144145146147148149150151152153154155156157158159160161162163164165166167168169170171172173174175176177178179180181182183184185186187188189190191192193
-- This function prepare csv table content from data and passed headers function generateCSVTable(rows, headers)   if #rows > 0 then     if #rows[1] > #headers then       error("There should be " .. tostring(#rows[1]) .. " header columns!")     end   end     -- Prepare .csv file   for k,v in ipairs(rows) do            rows[k] = table.concat(v, ",")     end   csv = table.concat(headers, ",") .. "\r\n" .. table.concat(rows, "\r\n")   return csv end -- Allows to add columns based on a current row or a previous one to current row function addColumnsToRow(row, prevRow, columnGetters)   for k,getter in ipairs(columnGetters) do     table.insert(row, getter(row, prevRow))   end   return row end -- Allows to add columns based on a current row or a previous one to every row function addColumnsToRows(rows, columnGetters)   local prev = nil   for k,row in ipairs(rows) do          rows[k] = addColumnsToRow(row, prevRow, columnGetters)     prev = row     end   return rows end function copyObject(obj)   return json.decode(json.encode(obj)) end -- This function prepare export table and .csv file from defined range function trend_export(name, dates, mode, timestampType)     require('trends')   -- detect timeShift   function detectTimeShift(t0, t1)   t0_isdst, t1_isdst = os.date('*t', t0).isdst, os.date('*t', t1).isdst     if (t0_isdst ~= t1_isdst) then       if (t1_isdst) then         -- change to summertime         return 1       else         -- change to wintertime         return 2       end     else       return false     end   end     require("json")   dates = copyObject(dates)   -- Convert word "now" in "start" to data table   if type(dates['start']) == "string" then     if dates['start'] == "now" then dates['start'] = os.date("*t", os.time())     elseif dates['start'] == "yesterday" then dates['start'] = os.date("*t", os.time()-24*3600)     elseif dates['start'] == "week_ago" then dates['start'] = os.date("*t", os.time()-7*24*3600)     elseif dates['start'] == "month_ago" then dates['start'] = os.date("*t", os.time()-30*24*3600)     elseif dates['start'] == "year_ago" then dates['start'] = os.date("*t", os.time()-365*24*3600)     end   end   -- Convert word "now" in "end" to data table   if type(dates['end']) == "string" then     if dates['end'] == "now" then dates['end'] = os.date("*t", os.time())     elseif dates['end'] == "yesterday" then dates['end'] = os.date("*t", os.time()-24*3600)     elseif dates['end'] == "week_ago" then dates['end'] = os.date("*t", os.time()-7*24*3600)     elseif dates['end'] == "month_ago" then dates['end'] = os.date("*t", os.time()-30*24*3600)     elseif dates['end'] == "year_ago" then dates['end'] = os.date("*t", os.time()-365*24*3600)     end   end            -- Start and end in unix time   starttime = os.time(dates['start'])   endtime = os.time(dates['end'])   -- Invert "start" and "end" when "end" is smaller than "start"   if starttime > endtime then     _ = dates['start']     dates['start'] = dates['end']     dates['end'] = _   end   -- Read trend resolution from DB   resolution = db:getlist("SELECT resolution*60 FROM trends WHERE name='" .. name .. "'")[1]   -- Prepare a table with the data which include the whole data from specified range   if resolution then       -- Expand a range with a one more day if there is some data in the last day     if (os.date("%H", endtime)*3600 + os.date("%M", endtime)*60) >= resolution then       dates['end'].day = dates['end'].day + 1       raw_data = trends.fetch(name, dates, resolution)     else       raw_data = trends.fetch(name, dates, resolution)     end     start = 1     data = {}     start_timestamp = os.time(dates['start']) + resolution     -- Cut the data and prepare a table with the data only from specified range     offset = 0     skip = 0     k = 1     while k <= #raw_data do       v = raw_data[k]             if k == 1 then last_timestamp = start_timestamp else last_timestamp = current_timestamp end       current_timestamp = start_timestamp + (k-1) * resolution + offset                   timeShiftStatus = detectTimeShift(last_timestamp, current_timestamp)       if timeShiftStatus then         if timeShiftStatus == 1 then -- winter->summer           skip = 6 -- skip 1 hour empty data           offset = offset - 3600         elseif timeShiftStatus == 2 then -- summer->winter           offset = offset + 3600         end       end             -- Add to new table only records from specified range       if current_timestamp >= starttime and current_timestamp <= endtime then         if timestampType == 'unixepoch' then data[start] = {current_timestamp, v}         else data[start] = {os.date('%Y.%m.%d %H:%M:%S', current_timestamp), v} end         start = start+1       end       k = k + 1 + skip       skip = 0     end          if mode == 'csv' then       -- Prepare .csv file       csv = generateCSVTable(data, { "timestamp", "value" })       return name, csv, resolution     elseif mode == 'table' then       return name, data, resolution     end   else       alert('There is no trend with such a name')   end end -- Merge values from multiple trends in one table function mergeRows(baseRows, rows)   for k,row in ipairs(baseRows) do     if k < 3 then log(k, "base", row) end     table.insert(baseRows[k], rows[k][2])     if k < 3 then log(k, "next", rows[k]) end   end   return baseRows end function getMultipleColumnHeader(names)   local columns = { "timestamp" }   for k,name in ipairs(names) do     table.insert(columns, name)   end   return columns end -- This function prepare export table and .csv file from defined range function multiple_trend_export(names, dates, mode, timestampType)   local baseRows = {}     for k,name in ipairs(names) do     local trend_name, rows = trend_export(name, dates, 'table', timestampType)     if #baseRows == 0 then       baseRows = rows     else       baseRows = mergeRows(baseRows, rows)     end   end     if mode == 'csv' then     -- Prepare .csv file     csv = generateCSVTable(baseRows, getMultipleColumnHeader(names))     return names, csv, resolution   elseif mode == 'table' then     return names, baseRows, resolution   end end
What's changed:
I've added these function:
addColumnsToRows(rows, columnGetters) - which will allow to add more columns and calculate values based on current row and a previous one
generateCSVTable(rows, headers) - which will produce a csv table content with named headers which should have same length as data rows
multiple_trend_export(names, dates, mode, timestampType) - which can be used for generating a table with multiple trends
Usage example:
require('user.trends_pro') dates = {} dates['start'] = 'yesterday' dates['end'] = 'now' name, rows = trend_export("Salon_Temperatura", dates, 'table', 'unixepoch') addColumnsToRows(rows, {     function(row, prevRow)       local value = row[2]             local prevValue = 0       if prevRow then prevValue = prevRow[2] end                   if value > 3 or prevValue > 3 then         return "YES"       else         return "NO"       end     end }) csv = generateCSVTable(rows, { 'timestamp', 'value', 'isBiggerThan3' }) log(name, csv) -- Generating a table with multiple trends in same rows names, rows = multiple_trend_export({"Kitchen_Temp", "Outdoor_Temp"}, dates, 'csv', 'unixepoch') log(names, rows)
Hi!
Thanks for your effort with this Lib ! I is very useful !
I have tried it and noticed a small difference from the Export from Visualization and the Export from the Script.
The resolution for this trends I have tested are 30min.
There is an offset of 30 minutes in the timestamp:
-- This the timewindow I have used to test dates = {} dates['start'] = { year = 2022, month = 6, day = 1hour = 0, min = 0, sec = 0} dates['end']   = { year = 2022, month = 7, day = 1hour = 0, min = 0, sec = 0}
