pid heating cooling
Hello to everynone,
I have completed a project using 13 pid control in one script. Everything is working except from the invert function in pid. for example one pid control is the following
if not p then
    p = PID:init({
      current = '0/0/1',
      setpoint = '0/0/2',
      manual = '32/1/1',
      inverted = true,
      output = '32/1/2',
      min=0,
      max=100,
      kp=1,
      ki=1,
      kd=1
p:run()
but when i an writhing false in the field inverted nothing is happened.
how i will invert the logic (heating cooling)?
Thank you in advance
Restart the script via disable/enable.
(08.07.2022, 13:22)admin Wrote: Restart the script via disable/enable.
Thank you for your answer,
I intend to have a group adress in this field, But if the disable/ enable is necessary everytime the system goes from heating to cooling and the opposite, what i have to do? is there any way to make this via another script?
Thank you
You can attach an event script to the heating/cooling mode change and then restart resident PID script like this:
script.disable('scriptname') script.enable('scriptname')
