massive data logging
Hi, I need to trend log about 250/300 KNX objects.
I know that's over LM possibilities due the 21 Mb archive limit.
Can you suggest an appropriate device to do this job?
I already knows BAB TECHNOLOGIE GmbH DATALOGGER V2 (https://bab-technologie.com/datalogger-v2/?lang=en), it could be ok.
But I trust in your experience and I would receive a suggest.
Peppe
With low resolution / retention settings you could fit 300 trends into LM. An alternative solution is to use Grafana - either cloud-hosted or by installing it locally on a small PC. Installation can be a bit tricky but it's a very flexible solution for storing time-series data.
Grafana seems to be very cool! And how to connect LM to it, sending telegrams via remote access?
LM is sending data to InfluxDB using HTTP. This thread has working examples: https://forum.logicmachine.net/showthread.php?tid=1531
Another option is MQTT: https://grafana.com/blog/2021/08/12/stre...fana-live/
(07.09.2022, 07:47)admin Wrote: LM is sending data to InfluxDB using HTTP. This thread has working examples: https://forum.logicmachine.net/showthread.php?tid=1531
Things are little changed on InfluxDB:
https://docs.influxdata.com/influxdb/clo...fluxdb-api
it seems a little too complicated to me... no shorter ways to implement a massive data logging?
Peppe
You only need to create a bucket once. It will store your data for a certain amount of time. There are examples of sending data to influx v2 in the topic I've linked to.
The setup part is a bit complicated but you only have to do it once Smile
(14.09.2022, 11:33)admin Wrote: You only need to create a bucket once. It will store your data for a certain amount of time. There are examples of sending data to influx v2 in the topic I've linked to.
I accepted the challenge! Smile
But right now I get error messages:
* arg: 1
  * string: error sending to influx
* arg: 2
  * string: {"code":"invalid","message":"at line 1:36: cannot parse value for field key \"value\": invalid float value syntax (check rejected_points in your _monitoring bucket for further information)"}
* arg: 3
  * number: 400
* arg: 4
  * string: rawdata,name=ora,addr=33/1/9 value=10:57
and
* arg: 1
* arg: 2
  * string: {"code":"invalid","message":"at line 1:47: cannot parse value for field key \"value\": invalid bool value \"Thu\" (check rejected_points in your _monitoring bucket for further information)"}
* arg: 3
  * number: 400
* arg: 4
  * string: rawdata,name=giornomeseanno,addr=33/1/8 value=Thu 15-09-2022
the script I used is the following, can you help me?
local http = require('socket.http')
http.TIMEOUT = 5
local dt_cache = {}
function get_value(addr, datahex)
  local dt = dt_cache[addr]
  if(not dt) then
    dt = grp.find(addr)
    dt_cache[addr] = dt
  return knxdatatype.decode(datahex, dt.datatype), dt
function knx_callback(event)
  local addr = event.dst
  local value, dt = get_value(addr, event.datahex)
  send_metric('rawdata', dt.name, addr, value)
function send_metric(table, name, addr, value)
  if name == nil or name == '' then
    return
  name = string.gsub(name, ' ', '\\ ')
  local url = 'https://europe-west1-1.gcp.cloud2.influxdata.com/api/v2/write?bucket=XX&org=XXX'
  local body
  if type(value) == 'boolean' then
    body = string.format('%s,name=%s,addr=%s state=%s', table, name, addr, value)
    -- most likely number
    body = string.format('%s,name=%s,addr=%s value=%s', table, name, addr, value)
  local res, code = http.request({
    url = url,
    method = 'POST',
    body = body,
    headers = {
      Authorization = 'Token XXXXXXXXXXXXXXXXXXX'
  if code ~= 204 then
    log('error sending to influx', res, code, body)
function run_loop()
  local bus = require('localbus').new(1)
  bus:sethandler('groupwrite', knx_callback)
  local busfd = socket.fdmaskset(bus:getfd(), 'r')
  while(true) do
    res, fbus = socket.selectfds(10, busfd)
    if(fbus) then
      bus:step()
run_loop()
You're sending string data (10:57 and Thu 15-09-2022) which Influx does not understand. String values must be enclosed in quotes.
Try replacing lines 35..42 with this:
local body
if type(value) == 'boolean' or type(value) == 'number' then
elseif type(value) == 'string' then
  body = string.format('%s,name=%s,addr=%s value=%q', table, name, addr, value)
  log('invalid data type', addr, type(value))
  return
Currently this script sends values for all objects. There should be some filtering implemented so only the required data is pushed.
(15.09.2022, 09:23)admin Wrote: You're sending string data (10:57 and Thu 15-09-2022) which Influx does not understand. String values must be enclosed in quotes.
  local body
  return
ok, now it's collecting data.... and yes, I need to filter them.
I guess I have to modify the function knx_callback(event), but my object addresses are not in a specific range, so I need to implement a sort of list of addresses to send.
This example will push only objects that have influx tag attached.
http.TIMEOUT = 5
local objs = {}
local tagobjs = grp.tag('influx')
for _, obj in ipairs(tagobjs) do
  objs[ obj.address ] = {
    name = obj.name:gsub(' ', '\\ '),
    datatype = obj.datatype,
function callback(event)
  local obj = objs[ addr ]
  if obj then
    local value = knxdatatype.decode(event.datahex, obj.datatype)
    sendmetric('rawdata', obj.name, addr, value)
function sendmetric(table, name, addr, value)
  local body
    return
    url = url,
    method = 'POST',
    body = body,
    headers = {
  if code ~= 204 then
local busclient = require('localbus').new()
busclient:sethandler('groupwrite', callback)
while true do
  busclient:loop(1)
(15.09.2022, 12:55)admin Wrote: This example will push only objects that have influx tag attached.
http.TIMEOUT = 5
local objs = {}
  if obj then
  local body
    return
    url = url,
    method = 'POST',
    body = body,
    headers = {
  if code ~= 204 then
while true do
  busclient:loop(1)
Everything is fine (although I still have to learn how to handle the data to create a decent report Smile )
Now  I have the final step: to connect influxdb to Grafana.
I don't know how to choose the right authentication metod to connect it. Where to put the token and org name??!
If you switch to Flux query language then you can specify access token, org and bucket.
This might be helpful:
https://medium.com/@nanditasahu031/integ...b4aebb3368
https://blog.devgenius.io/grafana-influx...561e89b207
