With low resolution / retention settings you could fit 300 trends into LM. An alternative solution is to use Grafana - either cloud-hosted or by installing it locally on a small PC. Installation can be a bit tricky but it's a very flexible solution for storing time-series data.
You only need to create a bucket once. It will store your data for a certain amount of time. There are examples of sending data to influx v2 in the topic I've linked to.
The setup part is a bit complicated but you only have to do it once
(14.09.2022, 11:33)admin Wrote: You only need to create a bucket once. It will store your data for a certain amount of time. There are examples of sending data to influx v2 in the topic I've linked to.
I accepted the challenge!
But right now I get error messages:
* arg: 1
* string: error sending to influx
* arg: 2
* string: {"code":"invalid","message":"at line 1:36: cannot parse value for field key \"value\": invalid float value syntax (check rejected_points in your _monitoring bucket for further information)"}
* arg: 3
* number: 400
* arg: 4
* string: rawdata,name=ora,addr=33/1/9 value=10:57
and
* arg: 1
* arg: 2
* string: {"code":"invalid","message":"at line 1:47: cannot parse value for field key \"value\": invalid bool value \"Thu\" (check rejected_points in your _monitoring bucket for further information)"}
* arg: 3
* number: 400
* arg: 4
* string: rawdata,name=giornomeseanno,addr=33/1/8 value=Thu 15-09-2022
the script I used is the following, can you help me?
local socket = require('socket')
local http = require('socket.http')
http.TIMEOUT = 5
local dt_cache = {}
function get_value(addr, datahex)
local dt = dt_cache[addr]
if(not dt) then
dt = grp.find(addr)
dt_cache[addr] = dt
return knxdatatype.decode(datahex, dt.datatype), dt
function knx_callback(event)
local addr = event.dst
local value, dt = get_value(addr, event.datahex)
send_metric('rawdata', dt.name, addr, value)
function send_metric(table, name, addr, value)
if name == nil or name == '' then
return
name = string.gsub(name, ' ', '\\ ')
local url = 'https://europe-west1-1.gcp.cloud2.influxdata.com/api/v2/write?bucket=XX&org=XXX'
local body
if type(value) == 'boolean' then
body = string.format('%s,name=%s,addr=%s state=%s', table, name, addr, value)
-- most likely number
body = string.format('%s,name=%s,addr=%s value=%s', table, name, addr, value)
local res, code = http.request({
url = url,
method = 'POST',
body = body,
headers = {
Authorization = 'Token XXXXXXXXXXXXXXXXXXX'
if code ~= 204 then
log('error sending to influx', res, code, body)
function run_loop()
local bus = require('localbus').new(1)
bus:sethandler('groupwrite', knx_callback)
local busfd = socket.fdmaskset(bus:getfd(), 'r')
while(true) do
res, fbus = socket.selectfds(10, busfd)
if(fbus) then
bus:step()
run_loop()
You're sending string data (10:57 and Thu 15-09-2022) which Influx does not understand. String values must be enclosed in quotes.
Try replacing lines 35..42 with this:
local body
if type(value) == 'boolean' or type(value) == 'number' then
elseif type(value) == 'string' then
body = string.format('%s,name=%s,addr=%s value=%q', table, name, addr, value)
log('invalid data type', addr, type(value))
return
Currently this script sends values for all objects. There should be some filtering implemented so only the required data is pushed.
(15.09.2022, 09:23)admin Wrote: You're sending string data (10:57 and Thu 15-09-2022) which Influx does not understand. String values must be enclosed in quotes.
local body
return
ok, now it's collecting data.... and yes, I need to filter them.
I guess I have to modify the function knx_callback(event), but my object addresses are not in a specific range, so I need to implement a sort of list of addresses to send.
This example will push only objects that have influx tag attached.
http.TIMEOUT = 5
local objs = {}
local tagobjs = grp.tag('influx')
for _, obj in ipairs(tagobjs) do
objs[ obj.address ] = {
name = obj.name:gsub(' ', '\\ '),
datatype = obj.datatype,
function callback(event)
local obj = objs[ addr ]
if obj then
local value = knxdatatype.decode(event.datahex, obj.datatype)
sendmetric('rawdata', obj.name, addr, value)
function sendmetric(table, name, addr, value)
local body
return
url = url,
method = 'POST',
body = body,
headers = {
if code ~= 204 then
local busclient = require('localbus').new()
busclient:sethandler('groupwrite', callback)
while true do
busclient:loop(1)
(15.09.2022, 12:55)admin Wrote: This example will push only objects that have influx tag attached.
http.TIMEOUT = 5
local objs = {}
if obj then
local body
return
url = url,
method = 'POST',
body = body,
headers = {
if code ~= 204 then
while true do
busclient:loop(1)
Everything is fine (although I still have to learn how to handle the data to create a decent report )
Now I have the final step: to connect influxdb to Grafana.
I don't know how to choose the right authentication metod to connect it. Where to put the token and org name??!
