24h Temperature average
Hello there
I've been trying to find a good solution to determine the average temperature of the day. My idea was it to trigger a script whenever a new value is being sent. I would then add the value to a variable and divide it by the number of values. Shortly befor midnight I would then store the value and clear counter and sum.
I also looked a the log option, but I get the impression that I have very few log entries of any group address that I log.
How could I achieve that? If you can point me to a similar code sample that be very helpful.
Thanks a lot!
Cheers!
Martin
Hi Martin,
I made the moving average in my solution as following:
1. Create object / group address for the average value (example: 49/0/1)
2. Create time triggered script with 5min cycle time
3. Use the following code inside the script and adjust the value group address:
average=grp.getvalue('49/0/1') value=grp.getvalue('49/0/2') —- value that should be averaged average = (average *((24*60/5)-1) + value)/(24*60/5) grp.checkwrite('49/0/1', average)
I hope this is working for you!
Best Regards
Steffen
https://forum.logicmachine.net/showthrea...7#pid17347
Another option is to use storage.
1. Event script to accumulate the values:
value = event.getvalue() key = 'average' storage.exec('incrbyfloat', key .. ':acc', value) storage.exec('incr', key .. ':cnt')
2. Scheduled script to calculate the average and reset the accumulated values:
key = 'average' acc = storage.get(key .. ':acc', 0) cnt = storage.get(key .. ':cnt', 0) avg = 0 if cnt > 0 then   avg = acc / cnt end grp.update('1/1/1', avg) storage.delete(key .. ':acc') storage.delete(key .. ':cnt')
(18.09.2022, 18:23)Hi SteffenThanks a lot, this looks like a neat solution. I shall try it this weekend and report.Cheers!Martinpioneersteffen Wrote: Hi Martin,
Best Regards
Steffen
(19.09.2022, 07:28)Daniel Wrote: https://forum.logicmachine.net/showthrea...7#pid17347
thanks Daniel for the pointer.
(19.09.2022, 08:15)admin Wrote: Another option is to use storage.
thank you very much, I shall try this too.
