Notification of exceeding wind speed threshold
hello
I need to send a notification to telegram that a certain wind speed threshold has been exceeded.
To get started, create the following script as a proof of principle
require("user.Telegram")                         -- Requiere la librería de usuario valor_actual_viento = grp.getvalue('1/0/3') valor_umbral_viento = grp.getvalue('32/1/7') if valor_actual_viento >= valor_umbral_viento then message = 'Alarma de viento ' ..valor_actual_viento.. 'm/s'         -- Texto del mensaje a enviar telegram(message)                             -- Se pasa a la biblioteca de usuario el mensaje log(message)   end
The problem is that while the wind alarm signal is above the threshold, notifications are sent continuously, I only want it to be sent once and require user action to dismiss the alarm.
How could I do it?
Thank you
Hello JRP!
You can make a script for current wind speed object. You will have three objects 1.)current wind speed, 2.)wind speed threshold 3.)alarm (boolean object)
local wind_current = grp.getvalue('34/1/57') local wind_treshold = grp.getvalue('34/1/59') local alarm = grp.getvalue('34/1/60') -- if alarm was already running do not send new telegram if ( (wind_current >= wind_treshold) and not alarm ) then   grp.write('34/1/60', true) -- set alarm true   message = 'Alarm wind speed is ' .. wind_current .. ' m/s'   log(message) end
Every time when wind speed changes, script will check the value of wind speed, if it is above threshold value (and alarm was off) it sets alarm object value to true and sends log. Next time if alarm was on (alarm object value was true) it will not send any log (till you unset the alarm object).
thanks i will try it.
Greetings
Hello
The script does not work, the message to telegram says sending.
The funny thing is that once the alarm has been activated and the notification is not supposed to be sent to Telegram, the log does not appear, but the notification is sent.
I have put the else statement, a variable with a fixed text and a log and the first time the text is not shown in the log (notification 1), the second time the text is shown and the notification continues to be sent.
Very rare indeed.
Any ideas?
Thank you
Post your full script. Most likely your telegram call is outside of "if" block.
Hello
That's what I thought, but it's the same script as the one proposed but with my variables and addresses.
This is the script
require("user.Telegram")                                       -- Requiere la librería de usuario local valor_actual_viento = grp.getvalue('1/0/3') local valor_umbral_viento = grp.getvalue('32/1/7') local alarma = grp.getvalue('32/2/25') if ( (valor_actual_viento >= valor_umbral_viento) and not alarma ) then   grp.write('32/2/25', true) -- set alarm true   message = 'Alarma de viento ' ..valor_actual_viento.. 'm/s' -- Texto del mensaje a enviar   telegram(message)                                           -- Se pasa a la biblioteca de usuario el mensaje   log(message)   else saltado = "saltado" log(saltado) end
Any suggestion?
Greeting
Check errors on telegram like this
res, err = telegram(message)
log(res, err)
Check that you don't have any other telegram() calls in Common functions, user library or in a duplicate script.
