Script to Monitor Remote System -
I have a script which I use to monitor the zones in a remote alarm system.    It's a looping script which processes the data coming in from a socket connection.  I need one instance of the script running continuously.
What's the best place to locate this (script below) - is it as a resident script with a 0 interval time or as an init script or somewhere else?
Many thanks in advance
Kind Regards,
James
-- Initialise socket connection if not sock then   require('socket')   sock, err = socket.connect('192.168.1.100', 2401)   if sock then     sock:settimeout(1)   else     log('Error connecting ' .. err)     sleep(5)   end end -- Process data received if sock then        while true do     rec = sock:receive('*l')     if rec then              data = lmcore.hextostr(rec, true)       st, addr, len, cmd, event, id, area = data:byte(1, 7)           if (event == 0) then           log('Door open in Zone ' .. id)         else           log('Door closed in Zone ' .. id)         end           end   end   end
You can make multiple copies of this script as a resident script with sleep time set to 0. init script should not have any blocking or long-running parts.
Also non-blocking connect should be used and possible errors during receive should be checked:
if not sock then   sock = require('socket').tcp()   sock:settimeout(1)   res, err = sock:connect('192.168.1.100', 2401)   if not res then     log('connect failed', err)     sock:close()     sock = nil     os.sleep(1)   end end if sock then       res, err = sock:receive('*l')   if res then     -- parse res   elseif err == 'closed' then     log('connection closed')     sock:close()     sock = nil   end end
Thanks for the script refinements. I’m still a little confused - if this shouldn’t be run a resident or Init script then what type of script would you suggest I create this as?
Kind Regards
James
I've never said it shouldn't be a resident script. Resident script is exactly what is needed for such task.
But won’t multiple instances of the same script running cause issues / use up all the available device memory?
What time interval would you suggest or modifications to the script to avoid the above?
Kind Regards
James
You can run multiple instances without any issues. Sleep interval must be set to 0 in this case. Most of the time the script is in a suspended state waiting for data to arrive so it does not consume CPU resources.
Thanks for clarifying. Many thanks.
