From Julian day to date
Ciao to all,
I've made a small script that convert back the julian day to the specific date.
Using the
local cDate = os.date('*t')
you can get the cDate.yday that represent the julian day (counting 1 from Jan 1st)
Apparentely there is no backformula that giving the year and the day, returns the complete date...
Well, I've made it:
function j2d(yd, aaaa)   local mm, dd = 1, 1   local cDate  = os.date('*t')   local mdays  = {31,28,31,30,31,30,31,31,30,31,30,31}   if not aaaa then aaaa = cDate.year end   if aaaa % 4 == 0 then mdays[2] = 29 end   for m = 1, 12 do     if mdays[m] > yd then       yd = yd - mdays[m]       mm = m     else       dd = yd       break     end   end   yDate   = os.date('*t', os.time({year = aaaa, month = mm, day = dd}))   yString = os.date('%d/%m/%Y',os.time({year = aaaa, month = mm, day = dd}))   return yString, yDate end
this functin can be saved into the common user function and be called by:
local cDate, tDate = j2d(270, 2022)
this will return the string for the date and the os.date('*t') table for the selected day...
hope this would help you somehow
ciao
M
