Thermostat Script
Hi folks, can anyone suggest (or kindly give a snippet) how to create a simple thermostat script?
The idea is to have 3 GA - current temperature, setpoint temperature and control valve (1 bit output).
And turn on/off the output control valve depending on the current temperature and setpoint values with a given hysteresis (e.g. 1 degree).
(28.12.2022, 22:52)mishoboss Wrote: Hi folks, can anyone suggest (or kindly give a snippet) how to create a simple thermostat script?
create event based script, map it on tag "thermostat1", map the same tag to current and setpoint objects. paste code to script (change GA addresses to what you need)
cur = grp.getvalue('current temp address or name')
set= grp.getvalue('setpoint temp address or name')
if set > cur then
  grp.write('valve  address or name', true)
  grp.write( 'valve  address or name', false)
