Display time of object
#21
(29.12.2021, 16:04)admin Wrote: Make sure you use a scheduled script that runs every minute not a resident script with low or 0 sleep time.
I did not understand, I used your scrap, I should change something there (in scrap)?
This solution consists of two scripts:
1. Event script which saves the time when the load has been turned on
2. Scheduled script that calculates the run time every minute
If you say that you get high CPU load then check that the second script is not a resident script with 0 sleep time.
This is how the scheduled script should be configured:
i change my event based script (a little), i had the problem, when i again get a off on my event, i got my value twice or more 'Last Run: '..Last_Run..' on'..time
so on my visualization i saw 'Last Run: Last Run: Last Run: 00:06 on Thu, 30-12 on Thu, 30-12 on Thu, 30-12'
Laptop_Seat = event.getvalue()            --'0 WCD Woonkamer - laptoplader Seat (tm)' ontime_Laptop_Seat = 'ontime_Laptop_Seat' output_Laptop_Seat = '32/1/202'            --'0 WCD Woonkamer - laptoplader Seat [timer on]' if Laptop_Seat then   if not storage.get(ontime_Laptop_Seat) then     storage.set(ontime_Laptop_Seat, os.time())     grp.update(output_Laptop_Seat, '00:00')   end elseif               -- <------------ and this to elseif          storage.get(ontime_Laptop_Seat) then        --  <------------i add this line   Last_Run = grp.getvalue(output_Laptop_Seat)   time = os.date(' %a, %d-%m',time)   grp.update(output_Laptop_Seat, 'Last Run: '..Last_Run..' on'..time)   storage.delete(ontime_Laptop_Seat) end
Modified script version that has total and current running time.
1. Add to Common functions:
function formattime(output, seconds)   local minutes = math.floor(seconds / 60)   local hours = math.floor(minutes / 60)   local days = math.floor(hours / 24)   local res = {}   seconds = seconds % 60   minutes = minutes % 60   hours = hours % 24   if days > 0 then     res[ #res + 1 ] = days .. 'd'   end   if hours > 0 then     res[ #res + 1 ] = hours .. 'h'   end   if minutes > 0 then     res[ #res + 1 ] = minutes .. 'm'   end   if seconds > 0 or #res == 0 then     res[ #res + 1 ] = seconds .. 's'   end   res = table.concat(res, ' ')   grp.update(output, res) end
2. Event script mapped to load on/off status:
value = event.getvalue() key_curr = 'ontime_curr' out_curr = '32/1/5' key_total = 'ontime_total' out_total = '32/1/16' time = storage.get(key_curr) now = os.time() if value then   if not time then     storage.set(key_curr, now)     formattime(out_curr, 0)   end else   if time then     time_total = storage.exec('incrby', key_total, now - time)     formattime(out_total, time_total)         storage.delete(key_curr)   end   grp.update(out_curr, '') end
3. Scheduled script that runs every minute (or a resident script with sleep time > 0 if finer time resolution is needed):
key_curr = 'ontime_curr' out_curr = '32/1/5' key_total = 'ontime_total' out_total = '32/1/16' time_curr = storage.get(key_curr) if time_curr then     time_curr = os.time() - time_curr   formattime(out_curr, time_curr)     time_total = storage.get(key_total, 0)   formattime(out_total, time_total + time_curr) end
In both scripts key_curr, out_curr, key_total, out_total variables should be adjusted as needed. Make sure that these variables have the same values in both scripts.
Hi.
How can i reset the total timer?
Br
MR
Use this to reset the total timer:
key_total = 'ontime_total' out_total = '32/1/16' storage.delete(key_total) formattime(out_total, 0)
Thanks alot.
I have another problem you maybe can help me with.
If i have two time stamps and i want to get the difference between them.
Br
MR
-------------------------------------------------------------------------- value = event.getvalue() key_curr = 'ontime_curr' out_curr = '33/1/31' key_total = 'ontime_total' out_total = '33/1/30' time = storage.get(key_curr) now = os.time() if value then   if not time then     storage.set(key_curr, now)     formattime(out_curr, 0)   end else   if time then     time_total = storage.exec('incrby', key_total, now - time)     formattime(out_total, time_total)         storage.delete(key_curr)   end   grp.update(out_curr, '') end ---- ---- resident------------------------------- key_curr = 'ontime_curr' out_curr = '33/1/31' key_total = 'ontime_total' out_total = '33/1/30' time_curr = storage.get(key_curr) if time_curr then     time_curr = os.time() - time_curr   formattime(out_curr, time_curr)     time_total = storage.get(key_total, 0)   formattime(out_total, time_total - time_curr) -- negative placement end
Hello, it counts backwards but it doesn't keep the value that I have wrong? Could you put the hours to be subtracted in a group address?
Thank you
Here's a different formatting function that will only show the largest units for the time (days, hours, minutes, seconds):
function formattimealt(output, seconds)   local minutes = math.floor(seconds / 60)   local hours = math.floor(minutes / 60)   local days = math.floor(hours / 24)   local res   seconds = seconds % 60   minutes = minutes % 60   hours = hours % 24   if days > 0 then     res = days .. 'd'   elseif hours > 0 then     res = hours .. 'h'   elseif minutes > 0 then     res = minutes .. 'm'   else     res = seconds .. 's'   end      grp.update(output, res) end
If you have a fixed total run time then you can use this:
time_total = 22 * 3600 -- 22 hours in seconds time_remaining = math.max(0, time_total - time_curr)    formattimealt(out_total, time_remaining)
(02.01.2023, 08:47)admin Wrote: Here's a different formatting function that will only show the largest units for the time (days, hours, minutes, seconds):
hello, in which part of the script would it go? I'm lost, one is for events and the other for residents?
Thank you
Resident/Scheduled inside the if.
(03.01.2023, 08:58)Daniel Wrote: Resident/Scheduled inside the if.
it would be like this ??
--------------------------------------Common functions ------------------------
---------------------------------------Scheduled-------------------
value = event.getvalue() key_curr = 'ontime_curr' out_curr = '33/1/2'       -- Time on Grupo Electrogeno key_total = 'ontime_total' out_total = '33/1/1'      -- Total on time de Encendido Grupo Electrogeno time_total = '33/1/3'   --- total hours to deduct time = storage.get(key_curr) now = os.time() if value then   if not time then     storage.set(key_curr, now)     formattime(out_curr, 0)   end else   if time then     time_total = storage.exec('incrby', key_total, now - time)     formattime(out_total, time_total)         storage.delete(key_curr)   end   grp.update(out_curr, '') end
-------------------------------- Resident--------------------------
key_curr = 'ontime_curr' out_curr = '33/1/2'       -- Time on Grupo Electrogeno Grupo Electrogeno key_total = 'ontime_total' out_total = '33/1/1'      -- Time on Grupo Electrogeno Grupo Electrogeno time_total = '33/1/3'   --- total hours to deduct time_curr = storage.get(key_curr) if time_curr then     time_curr = os.time() - time_curr   formattime(out_curr, time_curr)     time_total = 22 * 3600 -- 22 hours in seconds time_remaining = math.max(0, time_total - time_curr)   formattimealt(out_total, time_remaining) end
Thank you
Second script is event not scheduled.
(04.01.2023, 08:56)admin Wrote: Second script is event not scheduled.
Hi, I don't understand what you mean, I'm very new to lua Sad Thank you
The second script starting with "value = event.getvalue()" must be an event script (script that is triggered by an object value change).
(05.01.2023, 08:13)admin Wrote: The second script starting with "value = event.getvalue()" must be an event script (script that is triggered by an object value change).
With your indications it works more or less for me;(, group time counter is set to 0, but the one that would have to be maintained and continue subtracting also goes to 0
value = event.getvalue('32/7/9') key_curr = 'ontime_curr' out_curr = '33/1/30 '       -- Time on Grupo Electrogeno key_total = 'ontime_total' out_total = '33/1/31'      -- Total on time de Encendido Grupo Electrogeno time = storage.get(key_curr) now = os.time() if value then   if not time then    storage.set(key_curr, now)     formattime(out_curr, 0)              end else if time then    time_total = storage.exec('incrby', key_total)            storage.delete(key_curr) end   grp.update(out_curr, '') end
key_curr = 'ontime_curr' out_curr = '33/1/30' key_total = 'ontime_total' out_total = '33/1/31' time_curr = storage.get(key_curr) if time_curr then     time_curr = os.time() - time_curr     formattime(out_curr, time_curr)    time_total = 22 * 3600 -- 22 hours in seconds       time_remaining = math.max(0,time_total - time_curr)     formattime(out_total, time_remaining)       end
Thank you
There is no way I tried according to indications and it doesn't work for me ;(
For this to work correctly some kind of external reset is also needed when the generator is fueled again. The easiest solution is to have a reset button on the visualization so the counter starts again. But the best approach would be to have a known fuel level in the generator so the process is fully automated..
(23.01.2023, 08:16)administración Wrote: Para que esto funcione correctamente, también se necesita algún tipo de reinicio externo cuando el generador se alimenta nuevamente. La solución más sencilla es tener un botón de reinicio en la visualización para que el contador comience de nuevo. Pero el mejor enfoque sería tener un nivel de combustible conocido en el generador para que el proceso esté completamente automatizado.
This is how I have assigned the group addresses for its operation, is this what you mean?  Thanks
If 3/0/10 contains the current fuel level you can calculate the remaining time based on that using an event script.
