Sending notifications with SIGNL4
SignL4 is a mobile alerting system.
They have a API, and have some examples at their homepage
Is it possible to use one of these snippets below to send notification from LM5?
The reason why I want to use this system is that I need a constant alert/sound/vibration on the phone until the user responds to the alarm
https://www.signl4.com/inbound-webhook-code-snippets/
Try this. Result and/or errors can be seen in the Logs tab.
secret = '12345' title = 'alert' message = 'alert from LM' http = require('socket.http') json = require('json') ltn12 = require('ltn12') data = json.encode({   Title = title,   Message = message, }) resp = {} res, code = http.request({   url = 'https://connect.signl4.com/webhook/' .. secret,   method = 'POST',   headers = {     ['content-type'] = 'application/json',     ['content-length'] = #data,   },   source = ltn12.source.string(data),   sink = ltn12.sink.table(resp), }) if res and code == 200 then   resp = table.concat(tbl)   log(resp) else   log(res, code) end
(23.01.2023, 11:37)admin Wrote: Try this. Result and/or errors can be seen in the Logs tab.
I get res = 1 and code = 404
resp:
"code": 3004,
  "requestId": "b33c1f40-ecb1-4b4c-9a83-a4d15e1e2e8c",
  "details": "No matching event source found.",
  "message": "Error raising event."
When I pase the url+secret in chrome i get this message:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<ErrorResponseContentBase xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<Details>You need to POST JSON content to your webhook URL. Find more information at: https://www.signl4.com/developers/webhook/inbound/</Details>
<Message>GET not supported.</Message>
</ErrorResponseContentBase>
The Lua code is more or less the same as other examples. Maybe some other fields have to be added to the JSON request. Contact SIGNL4 support.
