Modbus TCP slave example
#21
The source code is as follows:
https://forum.logicmachine.net/showthrea...,loop(0.1)
Lm as modbus rtu slave:
1.I need to add the 'inputregisters' and' discreteinputs' mapping list of the source code. How should I change the code?
2.Another problem is that if the value of the group address "1/1/1" of dt.float16 is 23 and the mapped register address value is 2300, how do you make their values correspond?
#22
Universal script has been update with RTU support: https://forum.logicmachine.net/showthread.php?tid=4288
