10.05.2023, 07:03
See LM firmware 2023.06: https://forum.logicmachine.net/showthread.php?tid=4816
[OLD] LogicMachine firmware 2023.04
10.05.2023, 07:03
12.05.2023, 17:48
(This post was last modified: 14.05.2023, 19:55 by CristianAgata.)
Hi Admin,
Thanks for your and all EMBS team work. Is it possible have a change log of the updates? Best regards Cristian
15.05.2023, 05:56
24.05.2023, 15:17
(This post was last modified: 24.05.2023, 15:26 by gjniewenhuijse.)
After upgrading LM5 Lite + Ext (i.MX6) i get no 1-wire tab and the following error:
Resident script:2: module 'ow' not found: no field package.preload['ow'] no file './ow' no file 'Library ow' no file 'Library ow' no file 'Library ow.so' stack traceback: [C]: in function 'require' I have an usb to 1-wire interface Solved: For LM5 install libow, owserver, luaow and genohm-scada-w1 packages
24.05.2023, 15:31
This is correct, now if LM does not have a real output for a package then it ia not installed. You can install it manually from additional packages.
08.06.2023, 04:11
Hi there,
I tried to upgrade my LM4 from firmware version 20211215 to 20230420. I used Google Chrome on macOS and selected the firmware "lm4-20230420.img" under "Upgrade firmware" in "System config." The upgrade finished without error messages, but even after clearing all browsing data I'm still stuck on version number 20211215. It's almost as if I reinstalled version number 20211215. Is the firmware upgrade to version 20230420 for LM4 on openrb.com broken? Any ideas how to best proceed from here? Thank you, -Bernd
08.06.2023, 07:01
Your LM micro SD card became read-only and must be replaced. Follow this guide: https://openrb.com/reflash-logicmachine3...-software/
