[OLD] LogicMachine firmware 2023.04
See LM firmware 2023.06: https://forum.logicmachine.net/showthread.php?tid=4816
Hi Admin,
Thanks for your and all EMBS team work.
Is it possible have a change log of the updates?
Best regards Cristian
Check changelogs for RC firmwares:
https://forum.logicmachine.net/showthread.php?tid=4424
https://forum.logicmachine.net/showthread.php?tid=4530
https://forum.logicmachine.net/showthread.php?tid=4572
https://forum.logicmachine.net/showthread.php?tid=4637
After upgrading LM5 Lite + Ext (i.MX6) i get no 1-wire tab and the following error:
Resident script:2: module 'ow' not found:
no field package.preload['ow']
no file './ow'
no file 'Library ow'
no file 'Library ow.so'
stack traceback:
[C]: in function 'require'
I have an usb to 1-wire interface
Solved: For LM5 install libow, owserver, luaow and genohm-scada-w1 packages
This is correct, now if LM does not have a real output for a package then it ia not installed. You can install it manually from additional packages.
Hi there,
I tried to upgrade my LM4 from firmware version 20211215 to 20230420.
I used Google Chrome on macOS and selected the firmware "lm4-20230420.img" under "Upgrade firmware" in "System config."
The upgrade finished without error messages, but even after clearing all browsing data I'm still stuck on version number 20211215.
It's almost as if I reinstalled version number 20211215.
Is the firmware upgrade to versionĀ 20230420 for LM4 on openrb.com broken?
Any ideas how to best proceed from here?
Thank you,
-Bernd
Your LM micro SD card became read-only and must be replaced. Follow this guide: https://openrb.com/reflash-logicmachine3...-software/
