MODBUS - Can't write on registers
I created the attached modbus profiles for a fancoil. I CAN READ but I CAN'T WRITE on the holding registers (from 26301 to 26327).
What is wrong?
Peppe
.json   IC-Radiantore - Inv.json (Size: 6.62 KB / Downloads: 8)
.pdf   XIST00073-Targa da incasso_rendition MODBUS.pdf (Size: 796.39 KB / Downloads: 4)
Incorrect spelling: not writeble but writable
Ooops.... that's embarassing! Smile
i did the fix, but i still can't write to the logs.
Yet with a modbus tool software I can write in the registers, but in the 0x10 mode: write multiple registers, as reported in the pdf manual.
See this: https://forum.logicmachine.net/showthrea...e_multiple
The script in the post - I suppose should be put as init script - refers to a tcp modbus connection... I have an RTU. re
And how I can map the registers to knx addresses?
The suggestions is to use "write_multiple": 1 in your profile
(04.07.2023, 08:20)Daniel Wrote: The suggestions is to use "write_multiple": 1 in your profile
OK Thanks!
