Modbus Server logging writing IPs
Hello.
On our LMs a Modbus TCP Server is running roughly based on https://openrb.com/lm-as-modbus-tcp-slave/
All works fine but at one customer something sporadically writes nonsens into our holding registers.
Is it possible to log the IP-address of the writing Client?
Adding a log(mb) to the function mbwriteregisters(register, value) does not gain the wanted result.
Thanks,
Christian
You should use this script: https://forum.logicmachine.net/showthread.php?tid=4288
Modify the handler function in the resident script to alert IP/port for each connection:
123456789101112131415161718
local function handler(sock)   local ip, port = sock:getpeername()   alert('modbus connection from: %s:%d', ip, port)   copas.setErrorHandler(log)   sock = copas.wrap(sock)   sock:settimeout(60)   while true do     local res, err = mb.tcphandler(sock)     if not res then       break     end   end   sock:close() end
Thanks for your support.
I will try the new version of the Modbus Server, but this will take some time.
