Store value
I have been testing some basic scripting with the use of helpers on the left. I tried to make a script to store a value from 0-100%, and get that value after 10 seconds. But on the storage.get value I dont recieve any updated value from the storage. I see that in the description there must be a specific value? Does that mean that I cant store a value between 0-100?
-- set storage variable myobjectdata to a specified value (e.g. 0-100%) storage.set('32/1/1', 0-100) -- wait for 10 seconds os.sleep(10) -- mydata will be set nil when data was not found Forrigetime = storage.get('32/1/11')
You don't need to use storage in a single script, you can simply use variables:
value = 10 os.sleep(10) log(value) -- will log 10
Your script does not work because you have two different storage keys (32/1/1 and 32/1/11). If you want to work with objects/group addresses then you need to use grp.write()/grp.update() to write values and grp.getvalue() to retrieve them.
(24.10.2023, 07:49)admin Wrote: You don't need to use storage in a single script, you can simply use variables:
Thank you!
