Hello. There is a problem with script execution. I can't figure out what the reason is.
This code creates 2 scripts with the current sunrise and sunset times. I will not provide the contents of the created scripts, but if necessary I will provide them. The content is simple: turn the light group on or off. And the problem is that sometimes they just don't get done. I don't understand the reason...
Entry in script: log('done') doesn't output anything to the log.
Perhaps I missed something when creating the script? I checked it on 2 different LMs. The firmware on the devices is the same for 2023.
I'll add. The script is allowed and when I try to launch using the button in the browser, the launch is also unsuccessful, the script simply does not execute. The only way to run it is:
disable -> save -> enable -> run
local http = require("socket.http")
local json = require("json")
local url = "https://api.openweathermap.org/data/2.5/weather?lat=**,75&lon=**,61&appid=*******35447a18d48ad0b&units=metric"
function createOrUpdateScript(name, script, time)
local h_time, m_time = string.match(time, "(%d+):(%d+)")
local data = {
type = 'scheduled',
name = name,
active = 1,
params = string.format("%d %d * * *", m_time, h_time),
subparams = 0,
--script = '',
category = 'Service',
description = '',
local exists = script.get(data.name)
--log(exists)
if exists ~= nil then
log(data.name, 'Script exists, updating')
data.id = exists.id
db:update('scripting', data, { id = exists.id })
log(data.name, 'Script does not exist')
db:insert('scripting', data)
data.id = db:getlastautoid()
script.save(data, true)
script.reloadsingle(data)
--END FUNCTION
local response, status, headers, statusline = http.request(url)
if status == 200 then
local data = json.decode(response)
--log(data)
temp_min = data.main.temp_min
TempReal = data.main.temp
wind = data.wind.speed
dusk = os.date("%H:%M",data.sys.sunset)
sunrise = os.date("%H:%M",data.sys.sunrise)
rain = data.weather[1].main
createOrUpdateScript("Light_On", script, dusk)
os.sleep(0.5)
createOrUpdateScript("Light_Off", script, sunrise)
storage.set('temp', temp_min)
grp.write('2/2/5', wind)
grp.write('2/2/0', TempReal)
log('temp real ', TempReal)
-- HTTP
log("Errore. Status: " .. status)
telegram('Errore fetch weather. status: ' .. status)
if rain == "Clear" or rain == "Clouds" then
grp.write('2/2/4', false)
grp.write('2/2/4', true)
if (1 >= TempReal) and ( TempReal >= -10) then
grp.write('2/0/0', true)
grp.write('2/0/0', false)
endThis code creates 2 scripts with the current sunrise and sunset times. I will not provide the contents of the created scripts, but if necessary I will provide them. The content is simple: turn the light group on or off. And the problem is that sometimes they just don't get done. I don't understand the reason...
