Problem runnig script
Hello. There is a problem with script execution. I can't figure out what the reason is.
local http = require("socket.http") local json = require("json") local url = "https://api.openweathermap.org/data/2.5/weather?lat=**,75&lon=**,61&appid=*******35447a18d48ad0b&units=metric" function createOrUpdateScript(name, script, time) local h_time, m_time = string.match(time, "(%d+):(%d+)") local data = {     type = 'scheduled',     name = name,     active = 1,     params = string.format("%d %d * * *", m_time, h_time),     subparams = 0,     --script = '',     category = 'Service',     description = '', }      local exists = script.get(data.name)         --log(exists)     if exists ~= nil then         log(data.name, 'Script exists, updating')         data.id = exists.id         db:update('scripting', data, { id = exists.id })     else         log(data.name, 'Script does not exist')         db:insert('scripting', data)         data.id = db:getlastautoid()     end     script.save(data, true)     script.reloadsingle(data) end --END FUNCTION      local response, status, headers, statusline = http.request(url) if status == 200 then         local data = json.decode(response) --log(data)              temp_min = data.main.temp_min       TempReal = data.main.temp       wind = data.wind.speed       dusk = os.date("%H:%M",data.sys.sunset)       sunrise = os.date("%H:%M",data.sys.sunrise)       rain = data.weather[1].main       createOrUpdateScript("Light_On", script, dusk)       os.sleep(0.5)         createOrUpdateScript("Light_Off", script, sunrise)       storage.set('temp', temp_min)              grp.write('2/2/5', wind)       grp.write('2/2/0', TempReal)       log('temp real ', TempReal)   else     -- HTTP     log("Errore. Status: " .. status)       telegram('Errore fetch weather. status: ' .. status) end if rain == "Clear" or rain == "Clouds" then     grp.write('2/2/4', false)   else     grp.write('2/2/4', true)   end if (1 >= TempReal) and ( TempReal >= -10) then   grp.write('2/0/0', true)         else   grp.write('2/0/0', false)   end
This code creates 2 scripts with the current sunrise and sunset times. I will not provide the contents of the created scripts, but if necessary I will provide them. The content is simple: turn the light group on or off. And the problem is that sometimes they just don't get done. I don't understand the reason...
Entry in script: log('done') doesn't output anything to the log.
Perhaps I missed something when creating the script? I checked it on 2 different LMs. The firmware on the devices is the same for 2023.
I'll add. The script is allowed and when I try to launch using the button in the browser, the launch is also unsuccessful, the script simply does not execute. The only way to run it is:
disable -> save -> enable -> run
You can use scheduler events tied to sunrise/sunset instead of creating scheduled scripts.
(02.11.2023, 13:53)admin Wrote: You can use scheduler events tied to sunrise/sunset instead of creating scheduled scripts.
Yes, I can) But intresting why not working..
in future maybe i need create script dynamic and i'm will stuck
