ADD STRING TO OBJECT NAME
HI
I have to change the name of the object, I recovered the name, so far everything is ok, how do I check if it is different from nothing, also how do I rewrite the new name
to read I created a loop with the group addresses and I would also like to use it to rewrite if different from null.
Thank you
Use
if not value then
where value is your null string
(07.12.2023, 08:39)Daniel Wrote: Use
if not value then
 perfect
if i need read the name of object
in name var
after  I need rewite the new_name in the same address, how can I do it ?
Check this: https://forum.logicmachine.net/showthread.php?tid=3033
To find the name
https://kb.logicmachine.net/libraries/lua/#grpfindalias
to update it
https://kb.logicmachine.net/libraries/lu...eateconfig
