Get time and date from KNX to LM
There is an example about how we can write LM's time and date to group address.
But i need a revers example. I wan to read from KNX group address and write to LM's date and time.
Do you have an example ?
Regards,
The correct way is to use NTP as if you use the script from link below you will make jump in time and if a schedule event happen in the meantime you will miss the event.
https://openrb.com/example-change-timeda...pt-on-lm2/
