Zigbee sensor and thermostat
Good morning. I have 2 devices that uses Zigbee as transmission protocol.
The first one is a sensor from Schneider (SED-TRH-G-5045) which I can't pair with the Logic Machine. Do you know why?
The only reason that i found is about the type of Zigbee used, that in this case is Zigbee green power.
The second one is a thermosat  that I paired succesfully. I uploaded in the attachment the log export and the data from the informations in the device tab of the app.
Thank you in advance!
.txt   zigbee json.txt (Size: 258 bytes / Downloads: 12)
.txt   logs.txt (Size: 155.46 KB / Downloads: 7)
Green power devices are not supported.
TS0601 won't work due to not using standard ZigBee clusters: https://forum.logicmachine.net/showthrea...1#pid31021
(03.08.2023, 09:49)admin Wrote: Green power devices are not supported.
Thank you for the feedback. I will try to search another one.
Do you know a thermostat with 230V power supply and a contact for the heat valve that is already integrated in the Zigbee app?
I found this one on the forum but is too much complicated for my purpose...
link:  China ZigBee Fan Coil Thermostat (100V-240V) PCT504-Z factory and manufacturers | Owon Technology (owon-smart.com)
Good morning
Good Morning,
I received the new thermostat which was suggested in the forum. These are the device informations:
Manufacturer: OWON Technology Inc.
Model: PCT504-E
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- HvacThermostat (513)
- HvacFanCtrl (514)
- HvacUserInterfaceCfg (516)
- MsRelativeHumidity (1029)
Output clusters
- Time (10)
Endpoint 2
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- MsOccupancySensing (1030)
It is integrable in the Logic Machine app?
These supported devices should be plug and play:
https://openrb.com/docs/zigbee-devices.htm
(23.08.2023, 06:53)fleeceable Wrote: These supported devices should be plug and play:
Good morning.
Unfortunately, I cannot find a thermostat for my project in that list. This is why I searched in the forum as admin suggested and I found the thermostat that I sent last day.
In this project we have a lot of constraints...
Thank you anyway for the reply!
Preliminary profile for this device will be added in the next app version. It's not guaranteed that all features will be implemented and will work as we don't have the actual device to test them.
Hi!!
I have the same valve "TS0601". I´ve seen that in a bridge Github have integrated this valve.
https://www.zigbee2mqtt.io/devices/TS060...ostat.html
Is there any way to set/get comands from script with this valve? In this page you can see available features.
I can´t see HVAC commands in zigbee library: https://kb.logicmachine.net/libraries/zigbee/
I´ve seen some HVAC devices in zigbee compatibilites as Wiser thermostat: https://kb.logicmachine.net/misc/zigbee-devices/
Thanks!!
This has already been asked several times. TS0601 won't work due to not using standard ZigBee HVAC clusters: https://forum.logicmachine.net/showthrea...1#pid31021
