[OLD] LogicMachine firmware 2024.01
#21
Are you using KNX/IP secure? Is the communication between LM and KNX routers working correctly?
#22
(20.02.2024, 07:53)admin Wrote: Are you using KNX/IP secure? Is the communication between LM and KNX routers working correctly?
Hi. I'm not using knx secure. Yes, LM and routers is working. I can deliver command, but I can't see it in group monitor
#23
Which ETS connection mode is used? KNX/IP Routing (multicast) or KNX/IP Tunnel to LM?
#24
(20.02.2024, 09:47)admin Wrote: Which ETS connection mode is used? KNX/IP Routing (multicast) or KNX/IP Tunnel to LM?
In knx connection is selected IP routing (multicast to 224.0.23.12). If I'm phisically conected to ip network I can see LM traffic in group monitor using multicast (wifi adaptor). If I connect, locally or VPN, to an IP router (knx tunneling) I only see devices response in GROUP MONITOR, not LM telegrams. If I connect to router and use BUS MONITOR I can see LM telegrams. Kinda strange
#25
Sorry for your time. Problem is at knx/ip router. There are three same model (IPR/S 3.5.1 from ABB) and one of them just show this behaviour. Probably an internal error. Telegrams from Logic Machine show fine in another line and KNX/IP and routing from another device (not LogicĀ  Machine) neither show in affected gateway. Thank you
