bacnet alarm
Good morning
I have a question: I am monitoring a device through the LogicMachine device using the bacnet-client APP but I have not been able to generate an alarm that indicates the absence of the baCnet (disconnection of the ethernet cable).
This app doesn't have any alarm features but if you would use our script solution then you can also see the error.
https://kb.logicmachine.net/libraries/bacnet-client/
PERFECT!! THANK YOU VERY MUCH.
 Could someone share the BaCnet client file to install on a LogicMachine that does not have internet.
Which firmware and CPU do you have?
(21.02.2024, 17:42)Daniel Wrote: ¿Qué firmware y CPU tienes?
firmware V 2.8.3
CPU: ARMv7 processor 5 (v7l)
You cannot install our packages on SE hardware, this is not an app.
firmware V 2.8.3
Try this one
.ipk   bacnet-client.ipk (Size: 2.24 MB / Downloads: 5)
