	Threads: 39
		 (13.06.2023, 07:58)batistacaceres Wrote:   (13.06.2023, 07:34)admin Wrote:  Post what you have in ZigBee app logs.
[2023-06-13 09:52:46] CC: resetting device
[2023-06-13 09:53:06] CC: resetting device
[2023-06-13 09:53:26] CC: resetting device
[2023-06-13 09:53:46] CC: could not reset dongle
[2023-06-13 09:53:46] CC: error initializing
[2023-06-13 09:53:46] ZB: could not start coordinator
[2023-06-13 09:53:46] TASK zb_initialize aborted: stack traceback:
[C]: in function 'assert'
...tmp.a1T5qQlEly/files/store/daemon/zigbee/zigbee/core.lua:894: in function <...tmp.a1T5qQlEly/files/store/daemon/zigbee/zigbee/core.lua:890>
[2023-06-13 09:54:22] CC: resetting device
[2023-06-13 09:54:42] CC: resetting device
Hello, the same thing happens to me as my colleague and with the same error messages. In my case, in the upper right part, only a flashing red light appears. I have tried with another LM that had a previous version of the Zigbee app and it worked, when I updated it to the latest version it no longer works. I have tried to do everything you ordered below but without success. When executing the script in Alerts, the ERROR message appears
	Threads: 45
		Which gateway are you using - USB or RS232? Check that the connection mode is correct in ZigBee app Configuration.
	Threads: 39
		 (04.03.2024, 08:33)admin Wrote:  Which gateway are you using - USB or RS232? Check that the connection mode is correct in ZigBee app Configuration.
Yes RS232, the wiring and configuration is fine. This has stopped working with the latest version of the APP
	Threads: 45
		What is the exact hardware version of your gateway? Which app version is still working for you?
	Threads: 39
		04.03.2024, 10:29
(This post was last modified: 04.03.2024, 10:31 by davidchispas.)
		 (04.03.2024, 09:25)admin Wrote:  What is the exact hardware version of your gateway? Which app version is still working for you?
ZIG2MV11220015
I don't remember what the version was, but it has to be one from a year ago.
	Threads: 45
		This looks like either a hardware problem or outdated firmware on the gateway. Contact us via email for a replacement.
	Threads: 1
		Hello Daniel, Can you add more option in this product ?
Today we have RMS Voltage, Ampere and energy but the product have many more option
 https://github.com/fairecasoimeme/Zlinky_TIC
Thx
Manufacturer: LiXee
Model: ZLinky_TIC
Firmware version: 4000-0013
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 1
 Profile: 260
 Input clusters
 - Basic (0)
 - PowerCfg (1)
 - Identify (3)
 - SeMetering (1794)
 - HaElectricalMeasurement (2820)
 - HaMeterIdentification (2817)
 - 65382
 Output clusters
 - Ota (25)
Endpoint 242
 Profile: 41440
 Input clusters
 - GreenPower (33)
 Output clusters
 - GreenPower (33)
	Threads: 45
		@busta, we don't have plans to add any new measurement attributes at the moment.
You can read raw attributes via a script like this:
 Code: zb = require('applibs.zigbee')
addr = '000d6f000b7a9d76' -- Meter address
cluster = 0x0702 -- Metering
attrs = { 769, 770, 1024 } -- Multiplier, Divisor, ActivePower
res, err = zb.cmdsync('getattributes', addr, cluster, attrs)
if res then
  -- note that the returned attribute keys are strings, not numbers
  power = res['1024'] * res['769'] / res['770']
  log(power)
  log('zb read error', err)
	Threads: 12
		Hi there, @admin. Mind you add this profile? Thanks in advance.
Fingerbot Plus
 Code: Manufacturer: _TZ3210_j4pdtz9v
Model: TS0001
Device type: End device
Power source: Battery
Receive when idle: No
Endpoint 1
 Profile: 260
 Input clusters
 - OnOff (6)
 - 61184
 - Basic (0)
 Output clusters
 - Ota (25)
 - Time (10)
Reported attributes
 - calclevel: 0
 - onoff: false
 - prevlevel: 254
	Threads: 1
		25.04.2024, 17:17
(This post was last modified: 25.04.2024, 17:19 by busta.)
		hello i have a product Zigbee for counting. but the information are not updated automatically. i need to read the information manually to see the information.
Is it possible to change this to automatically updated the data ?
Manufacturer: LiXee
Model: ZLinky_TIC
Device type: Router
Power source: Mains
Endpoint 1
 Profile: 260
 Input clusters
 - Basic (0)
 - PowerCfg (1)
 - Identify (3)
 - SeMetering (1794)
 - 65382
 Output clusters
 - Ota (25)
Endpoint 242
 Profile: 41440
 Input clusters
 - GreenPower (33)
 Output clusters
 - GreenPower (33)
Reported attributes
 - currentsummdelivered: 6077858
 - rmscurrent: 2
 - rmsvoltage: 0
	Threads: 45
		@alexll, @busta, we'll add profiles for your devices in the next version.
	Threads: 2
I got hands on a LSS100400 RS232 Device, will i reconnect all my devices when switch from USB to RS232 ?
	Threads: 45
		It should work. But you need to turn off all permanently powered ZigBee devices and only turn them on once new gateway starts.
	Threads: 14
		 (26.04.2024, 09:59)admin Wrote:  @alexll, @busta, we'll add profiles for your devices in the next version.
Hello Admin, have you integrated the lixee product ? because i have the same issue.
Active Power don't appear.
 Manufacturer: LiXee
Model: ZLinky_TIC
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- PowerCfg (1)
- Identify (3)
- SeMetering (1794)
- 65382
Output clusters
- Ota (25)
Endpoint 242
Profile: 41440
Input clusters
- GreenPower (33)
Output clusters
- GreenPower (33)
Reported attributes
- currentsummdelivered: 6928895
- haactivepower: 0
- rmscurrent: 3
- rmsvoltage: 0
	Threads: 45
		Check that you have the latest ZigBee app installed. Delete your device from the app then reset the device and pair it again.
	Threads: 64
		Hi, Is there any way to get offline status of device and map them to KNX addresses?
	Threads: 45
		Online status can be done via a scheduled script.
If a device is battery powered then the maximum allowed delta should be increased from 1 hour (60 * 60) to 4 hours.
 Code: ieeeaddr = 'cc86ecfffe728382'
updatetime = db:getone([[
  SELECT updatetime
  FROM zb_devices
  WHERE ieeeaddr=?
]], ieeeaddr)
diff = os.time() - updatetime
delta = 60 * 60 * 1.1 -- max time delta in seconds +10%
online = diff < delta
grp.checkwrite('0/0/1', online)
	Threads: 64
		 (22.07.2024, 05:36)admin Wrote:  Online status can be done via a scheduled script.
  SELECT updatetime
  FROM zb_devices
  WHERE ieeeaddr=?
]], ieeeaddr)
Ok, thanks!
	Threads: 24
		Hi @all,
can you please add the following door lock to the devices?
Manufacturer: Danalock
Model: V3-BTZBE
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- PowerCfg (1)
- Identify (3)
- Alarms (9)
- PollCtrl (32)
- ClosuresDoorLock (257)
- HaDiagnostic (2821)
- 64767
Output clusters
- Ota (25)
Reported attributes
- lockstate: 1
Many thanks for your help!
Best regards
Steffen
	Threads: 39
SE ECO EXPERT
