email setting
our smtp server needs to enable tls. what is the right parameter for secure?
txs
Put tlsv12 there, but in most cases port 587 uses STARTTLS mode, so you need to install updated LuaSocket package. Which hardware are you using?
(10.10.2017, 12:24)admin Wrote: Put tlsv12 there, but in most cases port 587 uses STARTTLS mode, so you need to install updated LuaSocket package. Which hardware are you using?
I have 1 LM4
and 1 LM5
with last firmware and with luashocket 2.0.2-17 both.
My smtp server setting are
So do i need to install LuaSocket package?
Update package from System config-> System > Packages > Click (+) icon
Package for LM4:
https://dl.openrb.com/lm-17/pkg/luasocke...23_mxs.ipk
Package for LM5:
https://dl.openrb.com/lm-17-imx6/pkg/lua...3_imx6.ipk
First try with secure = 'starttls',
If it does not work then try secure = 'tlsv12',
In your script put mail function call inside log( ) so you can see an error message in logs if there is any.
(11.10.2017, 07:59)admin Wrote: Update package from System config-> System > Packages > Click (+) icon
Package for LM4:
https://dl.openrb.com/lm-17/pkg/luasocke...22_mxs.ipk
Package for LM5:
https://dl.openrb.com/lm-17-imx6/pkg/lua...2_imx6.ipk
hi
with secure = 'starttls' email() returns
* arg: 1
 * nil
* arg: 2
 * nil
 and with secure = 'tlsv12'
* arg: 1
 * nil
* arg: 2
 * string: closed
Can you send login/password that your are using via PM so I can check it locally?
(11.10.2017, 10:27)admin Wrote: Can you send login/password that your are using via PM so I can check it locally?
sent it
Thanks, please update packages again:
Package for LM4:
Package for LM5:
Replace mail() function in Common functions with this and change from/user/password field values to your access details:
function mail(to, subject, message)
  local settings = {
    from = '...',
    -- smtp username
    user = '...',
    -- smtp password
    password = '...',
    -- smtp server
    server = 'mailgate.cosmotemail.gr',
    -- smtp server port
    port = 587,
    -- enable tls
    secure = 'tlsv1',
    -- use STARTTLS mode
    starttls = true,
  if type(to) ~= 'table' then
    to = { to }
  for index, email in ipairs(to) do
    to[ index ] = '<' .. tostring(email) .. '>'
  -- fixup from field
  local from = '<' .. tostring(settings.from) .. '>'
  -- message headers and body
    headers = {
      to = table.concat(to, ', '),
      subject = subject,
      ['From'] = from,
      ['Content-type'] = 'text/html; charset=utf-8',
    body = message
  settings.from = from
  settings.rcpt = to
  return smtp.send(settings)
(13.10.2017, 08:45)admin Wrote: Thanks, please update packages again:
Package for LM4:
Package for LM5:
 local settings = {
   from = '...',
   -- smtp username
   user = '...',
   -- smtp password
   password = '...',
   -- smtp server
   -- smtp server port
   port = 587,
   -- enable tls
   secure = 'tlsv1',
   starttls = true,
   to = { to }
 -- fixup from field
   headers = {
     subject = subject,
     ['From'] = from,
   body = message
 settings.rcpt = to
it works perfect. Thank you very much
Can you send me the package for LogicMachine5 Lite Power?
It's already there:
Do I need LuaSocket package for HomelYnk also? Where can I find it?
Can I use the same user script with my u/p server settings?
Best,
Hi again,
Just wanted to share that I found a solution for my question form this link:
https://www.schneider-electric.com/en/do.../AN011_SL/
Best,
Hi all,
Can you help me to find the mistake in my script ?
function Email(to, subject, message)
  ---------------BEGINNING OF USER EDITABLE AREA-------------------
  local settings = {
    from = 'bouvet.clementine@gmail.com',
    -- smtp username
    user = 'bouvet.clementine@gmail.com',
    -- smtp password
    password = 'xxxxx',
    -- smtp server
    server = 'smtp.gmail.com',
    -- smtp server port
    port = 465,
    secure = 'sslv23',
  -------------------END OF USER EDITABLE AREA---------------------
  local escape = function(v)
    return '<' .. tostring(v) .. '>'
    headers = {
      to = escape(to),
      subject = subject,
    body = message
  -- fixup from field
  settings.from = escape(settings.from)
  settings.rcpt = { escape(to) }
There's no point in using another function, you can just use mail(to, subject, message) from common functions. You should also wrap mail function call with log(mail(...)) to see the mail server response which might contain an error of some sort.
What is wrong ?
-- user function library
  local settings = {
    from = 'XXXXXX@XXXXXX.COM',
    -- smtp username
    user = 'XXXXXX@XXXXXX.COM',
    -- smtp password
    password = 'XXXXXX',
    -- smtp server
    server = 'smtp.office365.com',
    -- smtp server port
    port = 587,
    -- enable tls
    secure = 'tlsv1.3',
    starttls = true
    to = { to }
  -- fixup from field
    headers = {
      subject = subject,
      ['From'] = from,
    body = message
  settings.rcpt = to
  log("send email:")
  log(settings)
Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthrea...1#pid33911
(27.03.2024, 09:29)admin Wrote: Log what the mail function returns as suggested here: https://forum.logicmachine.net/showthrea...1#pid33911
initscript 27.03.2024 09:44:38
* arg: 1
  * nil
* arg: 2
  * string: timeout
to:
    -- smtp server port
    port = 587,
    -- enable tls
    secure = 'tlsv1_3',
    starttls = true,
[Image: errir.png]
Check this
https://forum.logicmachine.net/showthrea...2#pid30472
* arg: 1
  * nil
* arg: 2
  * string: timeout
to:
    -- smtp server port
    port = 587,
    -- enable tls
    secure = 'tlsv1_3',
    starttls = true,
[Image: errir.png]
Did you managed to find the correct settings?
I'm also trying to send an email via the same smtp server :-) and getting the following error:
* arg: 1
  * number: 1
* arg: 2
  * nil
Thanks!
Niels
What you are getting is not an error but a normal result: first return value is 1 = ok, second is nil = no error.
