Threads: 28
Hi edgars,
is that working also in spacelynk?
Habib
Threads: 7
Hi Habib,
Yes it can work in SL but there is no front end to show it on, so without modification it's useless.
In new FW for SL there will be a front end so you have to wait a bit..
Threads: 2
Hello everyone,
Nice widget !
I wanted to have the exact same On/Off button yet not on the widget but on the separate page (the one when you click "Go to app"). I copy paste the <? blablidibla ?> code of the widget.lp script in the info.html but it does not work. I did write the <? require("apps") ?> at the beginning.
Can someone give me a hand on this please ? I think it is pretty simple but I cannot figure out what I misunderstand.
Thank you for your help.
Threads: 7
23.02.2017, 22:24
(This post was last modified: 23.02.2017, 22:25 by Erwin van der Zwart.)
The client side lua can only be started from files with .lp extentions. You can simply rename your info.html file to info.lp
Threads: 2
Hi Erwin thank you very much for your help I appreciate.
I did put the <? blablidibla ?> code of the widget.lp script in the info.html then rename to info.lp and updated the link to info.lp in widget.lp
Yet, the on/off icon does not appear in the page...
Threads: 2
Thank you Erwin !
Works like a charm.
Threads: 103
What is the main screen good for? Or maybe better question is How do you use it? Or which use has it been planned for?
I'm curious because I haven't found any use of this screen.
In reality I would be happy if this page disappears and simple http://<my_lm_IP> starts my visu with auto decision if I'm mobile or standard PC user. Admin tasks should be under /apps subfolder not available from the main page because it's confusing for a user to see it and it looks unprofessional.
Threads: 7
01.03.2017, 16:54
(This post was last modified: 01.03.2017, 16:56 by Erwin van der Zwart.)
Hi Thomas,
Main screen is base location for all kind of apps, you can decide what apps you want to use and show. There will be more apps allong time, so yes it's very usefull.
You already can select the base location for your direct IP landing in the user settings and bypass this screen.
There is no device detection but you can login from your mobile with other username and be redirected directly to your mobile visu.
So all your comments are covered already (:
Threads: 103
(01.03.2017, 16:54)Erwin van der Zwart Wrote: You already can select the base location for your direct IP landing in the user settings and bypass this screen.
It would be perfect. How can I do it?
Threads: 7
18.10.2017, 10:02
(This post was last modified: 18.10.2017, 10:03 by Erwin van der Zwart.)
This option is from old version firmware, in the current FW this is changed / removed.
