Splitting and merging values
Hello. I have a float value, with formatting 00.00. I need to separate the value at '.' . and on the other end, I need to merge them again.
Example: value read from GA= 12.02, values in script: val1=12 and val2= 02
Possible?
(24.04.2024, 12:50)tomnord Wrote: Hello. I have a float value, with formatting 00.00. I need to separate the value at '.' . and on the other end, I need to merge them again.
Possible?
value = grp.getvalue('57/0/1') --Split by dot tab = string.split(value, ".") log(tab) --Merge into 2byte if #tab >1 then   grp.update('57/0/2', tab[1] .. '.' .. tab[2]) else   grp.update('57/0/2', tab[1]) end
Should work...
Possible?
Should work...
Thanks, I'll try. But i thought the string.split only worked on strings, not floats.
Possible?
Should work...
It kinda works, but the last decimal does not write odd numbers. example, I write 23.53, the value written is 23.52, the same with 23.55, ends up as 23.54.. It only happens when main number is above 20
Logged value in "tab" shows correct numbers.
Simplified version (:
value = string.gsub(event.getvalue(), "%.", "") grp.update('10/0/1', value)
(25.04.2024, 06:02)tomnord Wrote: It kinda works, but the last decimal does not write odd numbers. example, I write 23.53, the value written is 23.52, the same with 23.55, ends up as 23.54.. It only happens when main number is above 20
2 byte floating point data type has lower precision with larger values. If you want higher precision then use 4 byte floating point if possible.
