email setting
#21
(09.05.2024, 10:36)admin Wrote: What you are getting is not an error but a normal result: first return value is 1 = ok, second is nil = no error.
Thanks. I'm not receiving the email though. See settings below. For the 'from' and 'user' field I'm using the same email adres together with the correct password, verified on "https://outlook.office.com/"
12345678910111213141516171819
-- send an e-mail function mail(to, subject, message)   -- make sure these settings are correct   local settings = {     -- "from" field, only e-mail must be specified here     from = 'xxxxxxxxxxxxxxxxxxxxxx',     -- smtp username     user = 'xxxxxxxxxxxxxxxxxxxxxx',     -- smtp password     password = ' xxxxxxxxxxxxxxxxxxxxxx',     -- smtp server smtp-mail.outlook.com / smtp.office365.com     server = 'smtp.office365.com',     -- smtp server port     port = 587,      -- enable tls     secure = 'ttlsv1_3',     -- use STARTTLS mode     starttls = true,   }
When using the following log code I'm getting the message below.
res, err = mail(to, subject, message) if not res then   log(err) end
* string: 535 5.7.139 Authentication unsuccessful, the request did not meet the criteria to be authenticated successfully. Contact your administrator. [LO4P123CA0481.GBRP123.PROD.OUTLOOK.COM 2024-05-09T10:33:51.352Z 08DC6E1D1ACB6079]
Is there any documentation with common tested SMTP servers?
Thanks in advance,
Niels
Check this: https://learn.microsoft.com/en-us/answer...successful
(09.05.2024, 10:55)admin Wrote: Check this: https://learn.microsoft.com/en-us/answer...successful
Thanks for your help. I'm not the maibox administrator so I created a gmail adress instead.  Rolleyes
Regards,
Niels
