array of group addresses
Hello. I have a task to write an array of identical values to a large number of group addresses (~200) ( like grp.write('1/*/*', value)). How can this be done using array commands?
Assign a common tag to the required objects then use this script:
value = 1 objects = grp.tag('my_tag_name') for _, obj in ipairs(objects) do   res = obj:checkwrite(value)   if res then     os.sleep(0.1)   end end
A better approach is to assign a common group address to all KNX devices because sending many telegrams at once can overflow the bus. The script above has a delay between each telegram to prevent this but it means that some devices will receive the value later.
