LM - "IP Tunneling" "IP Routing" and "Multicast IP"
I'm trying to understand the concept of "IP Tunneling" "IP Routing" and "Multicast IP" for LM
If I have 2 devices on the same VLAN imagine: 192.168.28.01 and  192.168.28.02:
     the device *.01 mode: TP-UART,  knx: 15.15.1 and multicast 224.0.23.12     and
     the device *.02 mode: IP-Tunneling : router: 192.168.28.01 (device 01), knx: 15.15.2 and multicast 224.0.23.12
Whit this I can send KNX frames from one to other with success and it's possible to update remote values... but
ETS return error programing device 01: "FAILED TO CONNECT TO 1.1.1"  .. if I remove the power of device 02, the programming is updated with success!
If I have a company with multiple VLANs, it's possible to connect all the to appear on ETS , to program devices from 1 vlan to others ?
The Mode defines how LM is connecting to KNX. If you select tunneling it means this LM is connected via another interface to TP and the locally connected TP is ignored.
TP-uart is a default mode with the TP and routing enabled. Routing mode is then just routing enabled but TP disabled.
Use TP-uart mode on all and in ETS you may need to use NAT if going from another Vlan
You can also use Zerotier and do it via cloud.
(05.04.2024, 12:49)joaodaniel.pereira Wrote: Hi,
(05.04.2024, 12:56)Daniel Wrote: The Mode defines how LM is connecting to KNX. If you select tunneling it means this LM is connected via another interface to TP and the locally connected TP is ignored.
ok, this is my original configuration, maybe between vlans port 3671 is blocked on the firewall!
Hii,
when trying to trigger light from knx via ip tunneling(logic machine) then its showing Failed to read devce description from 172.168.150.125, but ping succeeded.
Could you pls Suggest us solution.
Pls find attached Screenshot for our work
See this: https://forum.logicmachine.net/showthread.php?tid=4757
Hii ,
Now we have new IP range Still Program is not downloading or Triggering from ETS.
here I have attached screenshots of our work.
Change LM address to 1.1.255 and see again.
Is it just with this device or any?
(20.08.2024, 08:59)Daniel Wrote: Change LM address to 1.1.255 and see again.
Still it is not able to download after changed.
(20.08.2024, 10:18)Daniel Wrote: Is it just with this device or any?
its is happening with Every Device .
Is LM overloaded? What is the KNX status?
Try rebooting LM and restart ETS.
(20.08.2024, 10:26)Daniel Wrote: Is LM overloaded? What is the KNX status?
There are 61 pages in LM. ETS Showing Failed to connect indivisual Address like 1.1.213.
still  not downloading after restart both.
one more think I observed that knx Light is Triggering from Knx via LM. But not Downloading.
Go to LogicMAchine and check what you see in bottom right corner where CPU/IO, Memory and KNX is.
(20.08.2024, 10:40)Daniel Wrote: Go to LogicMAchine and check what you see in bottom right corner where CPU/IO, Memory and KNX is.
Here Is Sceeenshot.
OK this looks good.
In KNX connection, IP > Local filter, did you enable Apply filter to tunneling? It should be disabled.
(20.08.2024, 10:54)Daniel Wrote: OK this looks good.
What firmware do you use? it is not the latest.
Try change the ETS setting in project details (i) -> details -> Check "Use a low bus communication speed"
