23.03.2022, 11:51
Is it possible to add a new LM in existing cloud account?
					Logic Machine Cloud
		23.03.2022, 11:51
		23.03.2022, 11:58
		Yes, you can simply create new network in cloud copy the string and paste in LM cloud app.
If you want to add to existing network then generate new string.
		23.03.2022, 12:21
		23.03.2022, 12:25
		There was a limit of 5 networks per user. It has been increased to 10, try again now.
		23.03.2022, 13:25
		25.03.2022, 12:53
		Do you still get "No connection to cloud"? I've checked your networks and everything is ok.
		25.03.2022, 15:22
		21.03.2024, 06:30
		I would like to ask, is there any way for me to manage how many devices are connected to the cloud? Please advise
		21.03.2024, 07:25
		Click X to close Mosaic then click gear icon in the top right to go to the settings page. There you can manage your networks and devices.
		23.03.2024, 02:30
(This post was last modified: 23.03.2024, 02:34 by Hoang Hien.)
		23.04.2024, 23:51
(This post was last modified: 24.04.2024, 00:05 by Hoang Hien.)
		Sorry, may I ask, has there been any problem with LM cloud in this week ? My app and the customer's both connect to LM5 very slowly, remote connections via NAT port are still normal. Please advise, my customer is very angry
Currently me and my customer are using firmware lm5m3-20240124.img and lm5m3-20230607.img
		24.04.2024, 07:09
		On our side all works fine, it must be slower internet or something.
		24.04.2024, 10:22
		24.04.2024, 10:29
		The only requirement is that LM must have Internet access. Since LM acts as a client when connecting to cloud it does not require a static IP or port forwarding.
		14.05.2024, 12:02
(This post was last modified: 14.05.2024, 12:11 by Hoang Hien.)
	(24.04.2024, 10:29)admin Wrote: The only requirement is that LM must have Internet access. Since LM acts as a client when connecting to cloud it does not require a static IP or port forwarding. Can I send my connection information to the cloud via email? Can you check for me? Currently, the connection is still unstable. After checking, I will change the password Reply from 168.119.164.110: bytes=32 time=327ms TTL=43 Reply from 168.119.164.110: bytes=32 time=329ms TTL=43 Reply from 168.119.164.110: bytes=32 time=328ms TTL=43
		14.05.2024, 12:59
	(14.05.2024, 12:02)Hoang Hien Wrote:(24.04.2024, 10:29)admin Wrote: The only requirement is that LM must have Internet access. Since LM acts as a client when connecting to cloud it does not require a static IP or port forwarding. Send to PM
		14.05.2024, 13:52
	(14.05.2024, 12:59)Daniel Wrote:(14.05.2024, 12:02)Hoang Hien Wrote:(24.04.2024, 10:29)admin Wrote: The only requirement is that LM must have Internet access. Since LM acts as a client when connecting to cloud it does not require a static IP or port forwarding. Send to what? How can I send
		Hii sir ,
I want to login LM cloud but It showing error that is pre- login failed DNS server is- 8.8.8.8 Ip range is 192.168.0.10 Subnet mask -255.255.255.0
		14.09.2024, 06:33
		Make sure that a valid gateway is set in Network config. Go to System config > Status > Network utilities and run Ping to remote.logicmachine.net
