Timer for multiple toilet's vents
Hi, I need help with 60 vents control in administration building.
One off vent 6/1/0 need to be controlled with lights 3/0/7,3/0/9, 3/0/11 or 3/0/13. When one of this lights is switched ON more then 5 minutes, or all off lights are turned to OFF, then I need to switch vent ON for time that can be set over group adress 11/4/1 in seconds.
Thaks for help
This can be done with 2 resident scripts:
1. OR gate for light groups: https://kb.logicmachine.net/scripting/lo...-statuses/
2. Modified staircase timer that uses status from the OR gate: https://kb.logicmachine.net/scripting/staircase-timer/
We can help with the modifications but you need describe the vent logic in more detail:
  • Is the timer setting global for all vents or adjustable for each vent separately?
  • What should happen if the light switches on while the vent is already running? Should the timer continue running or stop?
  • What should happen if the light switches off while the vent is already running? Should the timer continue running as is or should it reset to the starting value?
(14.10.2024, 06:55)admin Wrote: This can be done with 2 resident scripts:
thaks for your answer. I look for scripts, but I need help with edit this script.
Time is same for all vents.
In both of case we want to retrigger running time and then switch off.
Timer script:
if not client then
  -- input to output mapping
  mapping = {
    ['0/0/1'] = '0/0/6',
    ['0/1/1'] = '0/1/6',
    ['0/2/1'] = '0/2/6',
  -- turn output on when input is on for X seconds
  ondelay = 5 * 60
  -- keep output on for X seconds
  offdelayaddress = '11/4/1'
  timers = {}
  for input, output in pairs(mapping) do
    timers[ input ] = {
      output = output,
      state = 'off',
  function timerset(timer, input)
    if input then
      if timer.state ~= 'ondelay' then
        timer.state = 'ondelay'
        timer.ticks = ondelay
      grp.checkwrite(timer.output, true)
      timer.state = 'offdelay'
      timer.ticks = grp.getvalue(offdelayaddress)
  function timertimeout(timer)
    if timer.state == 'ondelay' then
      timerset(timer, false)
      grp.checkwrite(timer.output, false)
      timer.state = 'off'
      timer.ticks = nil
  grp.sender = 'tm'
  client = require('localbus').new(0.1)
  client:sethandler('groupwrite', function(event)
    local timer = timers[ event.dst ]
    if timer and event.sender ~= grp.sender then
      local value = tonumber(event.datahex, 16) or 0
      timerset(timer, value ~= 0)
  end)
client:loop(1)
for _, timer in pairs(timers) do
  if timer.ticks then
    timer.ticks = timer.ticks - 1
    if timer.ticks == 0 then
      timertimeout(timer)
if not client then
  mapping = {
    ['0/1/1'] = '0/1/2',
  ondelay = 5 * 60
  offdelayaddress = '0/1/4'
  timers = {}
    timers[ input ] = {
      output = output,
      state = 'off',
    if input then
      timer.state = 'off'
      timer.ticks = nil
  grp.sender = 'tm'
  end)
client:loop(1)
  if timer.ticks then
      timertimeout(timer)
(5 hours ago)admin Wrote: Timer script:
if not client then
  mapping = {
  ondelay = 5 * 60
  timers = {}
    timers[ input ] = {
      output = output,
      state = 'off',
    if input then
      timer.state = 'off'
      timer.ticks = nil
  grp.sender = 'tm'
  end)
client:loop(1)
  if timer.ticks then
      timertimeout(timer)
I try with other adresses, but nothing happend on the bus. What I do wrong?
Works for me. Do you have it as resident script with 0 sleep time?
Enable logging for 0/1/1 and 0/1/2. Setting 0/1/1 to OFF should immediately set 0/1/2 to ON for 10 seconds.
(4 hours ago)admin Wrote: Works for me. Do you have it as resident script with 0 sleep time?
Yeah, it works, I have 60s time. Thank You
  groups = {
    --samples
    { tag = 'my_group_and', output = '4/0/0', mode = 'and' },
    { tag = 'my_group_or', output = '4/0/1', mode = 'or' },
    { tag = 'my_group_avg', output = '4/0/2', mode = 'avg' },
I dont understand what mean "my_group_or", it is possible to 4 adresses in this place to compare OR like this : tag = '3/1/10', '3/1/20', '3/1/24' , '3/1/47'       ??
