movement detection
Hello. I need that  script for movement detection-if there is movement, the actuator is triggered for a certain time1 . if the movement is repeated(while the actuator is ON), the actuator's operating time is extended for time 2
thanks
Is the time1 different then time2?
yes. movement1= 100seconds and each another movement will add 30seconds
Resident script with sleep time set to 0. In this example 0/0/1 is movement input (1 bit) and 0/0/6 is actuator output control (1 bit). Multiple timers can be added to the timers table if needed.
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748
if not client then   timers = {     ['0/0/1'] = {       output = '0/0/6', -- binary output control (0/1)       timeoutinit = 100, -- initial timeout in seconds       timeoutadd = 30, -- additional timeout in seconds     },   }   function timerset(timer, value, ticks)     timer.on = value     timer.ticks = ticks     grp.write(timer.output, value, dt.bool)   end   function timerstart(timer)     if timer.on then       timer.ticks = timer.ticks + timer.timeoutadd     else       timerset(timer, true, timer.timeoutinit)     end   end   grp.sender = 'tm'   client = require('localbus').new(0.1)   client:sethandler('groupwrite', function(event)     local timer = timers[ event.dst ]     if timer and event.sender ~= grp.sender then       local value = tonumber(event.datahex, 16) or 0       if value == 1 then         timerstart(timer)       end     end   end) end client:loop(1) for _, timer in pairs(timers) do   if timer.ticks then     timer.ticks = timer.ticks - 1     if timer.ticks == 0 then       timerset(timer, false)     end   end end
