movement detection
Hello. I need that  script for movement detection-if there is movement, the actuator is triggered for a certain time1 . if the movement is repeated(while the actuator is ON), the actuator's operating time is extended for time 2
thanks
Is the time1 different then time2?
yes. movement1= 100seconds and each another movement will add 30seconds
Resident script with sleep time set to 0. In this example 0/0/1 is movement input (1 bit) and 0/0/6 is actuator output control (1 bit). Multiple timers can be added to the timers table if needed.
if not client then
  timers = {
    ['0/0/1'] = {
      output = '0/0/6', -- binary output control (0/1)
      timeoutinit = 100, -- initial timeout in seconds
      timeoutadd = 30, -- additional timeout in seconds
  function timerset(timer, value, ticks)
    timer.on = value
    timer.ticks = ticks
    grp.write(timer.output, value, dt.bool)
  function timerstart(timer)
    if timer.on then
      timer.ticks = timer.ticks + timer.timeoutadd
      timerset(timer, true, timer.timeoutinit)
  grp.sender = 'tm'
  client = require('localbus').new(0.1)
  client:sethandler('groupwrite', function(event)
    local timer = timers[ event.dst ]
    if timer and event.sender ~= grp.sender then
      local value = tonumber(event.datahex, 16) or 0
      if value == 1 then
        timerstart(timer)
  end)
client:loop(1)
for _, timer in pairs(timers) do
  if timer.ticks then
    timer.ticks = timer.ticks - 1
    if timer.ticks == 0 then
      timerset(timer, false)
