link on scada-vis
is there a way to update the external link URL via script?
PEPPE
See this: https://forum.logicmachine.net/showthrea...6#pid11806
(30.10.2024, 15:41)admin Wrote: See this: https://forum.logicmachine.net/showthrea...6#pid11806
$(function() {
  $('.link').off('vclick').on('vclick', function() {
    window.open('http://openrb.com');
That's fine, but I need to pass the URL from a key in storage... is it possible?
Use a virtual object with 250 byte string data type (32/0/1 in this example).
$(function() {   if (typeof grp != 'object') {     return;   }      var url;   $('.link').off('vclick').on('vclick', function() {     window.open(url);   });   grp.listen('32/0/1', function(obj) {     url = obj.value;   }); });
(01.11.2024, 07:35)admin Wrote: Use a virtual object with 250 byte string data type (32/0/1 in this example).
in fact I had already thought of this solution, the problem is that the URL is too long and is truncated to 250 bytes as it contains an authentication token that changes every time:
http://10.0.0.146:8080/dashboard/28a2e20...8So-6_WXUw
You can create a .lp file that redirects to the specified URL from a storage entry. This way you don't need Custom JS at all. Link URL should be set to /user/redirect.lp.
<? require('apps') url = storage.get('redirect_url') if url then   ngx.req.discard_body()   ngx.redirect(url) end
(01.11.2024, 13:03)admin Wrote: You can create a .lp file that redirects to the specified URL from a storage entry. This way you don't need Custom JS at all. Link URL should be set to /user/redirect.lp.
sorry, but I have no idea about that...  as you can understand, I just need to set a button object or something to click on visu to open a new tab in the browser with the link.
Can you please give me the operating steps to do it?
where I have to put that code and how?
Create redirect.lp file and upload it to user directory via FTP using apps login.
You might still need custom JS to open URL in a new window/tab.
(01.11.2024, 13:25)admin Wrote: Create redirect.lp file and upload it to user directory via FTP using apps login.
in the end I found an italian way to do it Smile
event script for the button on visu
url = storage.get('dashboard_url', 'https://www.google.com/') lunghezza = string.len(url) n=1 dashboard_url='' for i = 1, lunghezza, 230 do     blocco = string.sub(url, i, i+229)       grp.write('33/2/'..n, blocco)   log (i, blocco)   sleep (0.5)   sottostringa = grp.getvalue('33/2/'..n)     dashboard_url = dashboard_url..sottostringa     n= n +1 end
and  JS
  // Funzione per aggiornare l'URL una volta ricevuti tutti i blocchi   function aggiornaUrl() {    // if (blocco1 && blocco2 && blocco3 && blocco4) {       url = blocco1 + blocco2 + blocco3 + blocco4;    // }   }   // Listener per ogni indirizzo di gruppo   grp.listen('33/2/1', function(obj) {     blocco1 = obj.value;     aggiornaUrl();   });   grp.listen('33/2/2', function(obj) {     blocco2 = obj.value;     aggiornaUrl();   });   grp.listen('33/2/3', function(obj) {     blocco3 = obj.value;     aggiornaUrl();   });   grp.listen('33/2/4', function(obj) {     blocco4 = obj.value;     aggiornaUrl();   }); });
Best regards
Peppe
