13.11.2024, 12:08
Your background is there only you are also using background on plan and it is overlapping it. Anything on plan will be above elements on Layout.
Cristian First test
13.11.2024, 12:08
03.12.2024, 18:52
(This post was last modified: 03.12.2024, 18:54 by CristianAgata.)
Hi Daniel,
May I ask the best practice to add additional CSS? I can't understand the syntace. And is there a way for layout to overlap the background? Best regards Cristian
04.12.2024, 11:35
Please describe in more detail what you want to adjust with Custom CSS.
04.12.2024, 11:40
04.12.2024, 11:49
Use inspector in browser dev tools (F12) to find CSS classes for relevant elements.
This example changes the font for the level/plan menu. Code: .tree-view {
font-family: Monospace;
04.12.2024, 11:54
(04.12.2024, 11:49)admin Wrote: Use inspector in browser dev tools (F12) to find CSS classes for relevant elements. Clear, thanks. About layout above main page background, do you think is it possible? Best regards
04.12.2024, 12:06
Please provide some details on what you want to achieve.
Layout works the same as in the old visualization. Stacking order from top to bottom is: - plan widgets - layout widgets - plan background - layout background
04.12.2024, 12:12
(04.12.2024, 12:06)admin Wrote: Please provide some details on what you want to achieve.Clear, When I came back office I will give you a screenshot of what I want realise. Thanks so much.
04.12.2024, 21:28
(This post was last modified: 05.12.2024, 08:57 by CristianAgata.)
(04.12.2024, 12:06)admin Wrote: Please provide some details on what you want to achieve.Hi admin, My will it is realise something like this (attached file): Stack order background -> layout -> widget Now I have added the strip with paint. Best regards Cristian
06.12.2024, 12:09
You can just use image on Layout if you want the graphical element to be on top of the plan background.
06.12.2024, 12:13
06.12.2024, 12:15
This should work, can you share the backup to show this limitation?
06.12.2024, 14:43
07.12.2024, 12:24
(06.12.2024, 12:15)Daniel Wrote: This should work, can you share the backup to show this limitation? Hi Daniel, check on the layout HOME_STRIP where you can see that the maxim width it is 1028 I need to reach 1280. Let me know if this it is the maximum width. Best regards Cristian
09.12.2024, 08:30
OK this is a bug, image should have no limit like this.
08.02.2025, 18:35
Hi Team,
I've found a strange behavior in the plan link, the icon of the link in plan view are ok in tile view is not ok (I've tested with several format WxH but all have problem). I attached the image. Best regards Cristian
10.02.2025, 07:13
Set "display mode" to "icon" or provide text for both states (active/inactive).
10.02.2025, 18:26
