underfloor
Hello guys i want your help with a script.
we have underfloor heating and pwm valves and i need the LM  to send a value (3%) to the heating if the value of the valve Is < 3%
every 30 minutes.
can anyone help me with the script ?
Do you need this to happen instantly or a script which runs every 30 min is fine to check the status and update?
(08.01.2025, 10:08)Daniel Wrote: Do you need this to happen instantly or a script which runs every 30 min is fine to check the status and update?
i want to happend  instantly..
i made a event base script  base on the valve group address
 if (0) then
value = 6
  sleep(40)
    grp.write('4/1/1', value)
but lm send many times the value with result to overload the tp
Use this:
value = event.getvalue() minvalue = 3 if value < minvalue then   grp.write(event.dst, minvalue) end
(08.01.2025, 11:07)admin Wrote: Use this:
Thank you it works perfectly !!!
Is there a way to do it if only the pump is on?
