08.01.2025, 11:41
I am experiencing an issue with the Astro function in Spacelynk, which previously worked perfectly fine for controlling outdoor lights based on sunrise and sunset times. The problem started on December 5th, and now the function behaves oddly. The lights turn on at 23:59 and turn off at 00:01, which is obviously not correct or functional.
I have tested the Astro function on three different installations with various firmware versions, and all of them show the same issue. Additionally, I moved the function to its own virtual group address in Spacelynk for logging purposes, but the problem persists. All installations are located in the same city, and here are the coordinates entered into Spacelynk (the values vary slightly between the installations, but these are representative):
Has anyone else encountered a similar issue, or does anyone have suggestions for possible solutions? I would appreciate any help.
Thank you in advance!
Best regards,
EL-KIM
- Coordinates: 68.71062, 15.39316
Best regards,
EL-KIM
