12.03.2017, 22:25
As it is not possible to have a graph with more than one variable, I decided to make my own graphs with rrdtool.
At first I was going to use another server that would collect data with remote xlm service, create the graph, put it on a webpage and display that graph in an iframe in LM.
I had progressed up to the point of moving the graph to the web server when it occurred to me that the rrdtool package is available in LM!![[Image: rolleyes.png]](http://forum.logicmachine.net/images/smilies/rolleyes.png)
The new plan was then to create an rrd archive in LM, put the graph in the img directory and then use that image in my visualisation.
What I did (this is in LM4 firmware 20160714):
-create a directory /data/storage/rrd
-create a rrd archive as follows:
-update the rrd with data:
-verify that data was being written with rrdtool first and rrdtool last
All this went well. I then wanted to create a graph as follows:
This fails, with the os.execute statement returning 256. Obviously no graph is created.
The manual states that the return code of os.execute is system dependent. I have no idea what values to expect on LM...
On the other machine this worked without any problems. The only difference is the version of rrdtool: on LM this is 1.4.7 whereas on the other machine it is 1.6
What is going wrong here?
create_rrd = "rrdtool create /data/storage/rrd/ventilatie.rrd --start N --step 300" ..
" DS:T_intake:GAUGE:600:-20:50" ..
" DS:T_supply:GAUGE:600:-20:50" ..
" DS:T_discharge:GAUGE:600:-20:50" ..
" DS:T_exhaust:GAUGE:600:-20:50" ..
" RRA:MIN:0.5:12:1440" ..
" RRA:MAX:0.5:12:1440" ..
" RRA:AVERAGE:0.5:1:1440"
result = os.execute(create_rrd)
-- get data
T_intake = grp.getvalue('4/1/11')
T_supply = grp.getvalue('4/1/12')
T_discharge = grp.getvalue('4/1/14')
T_exhaust = grp.getvalue('4/1/13')
log(T_intake ..":" ..T_supply..":" ..T_discharge..":" ..T_exhaust)
rrdupdate = "rrdtool update /data/storage/rrd/ventilatie.rrd N:" ..T_intake ..":" ..T_supply ..":" ..T_discharge ..":" ..T_exhaust
result = io.readproc(rrdupdate)
rrdgraph = "rrdtool graph /data/storage/img/ventilatie.png DEF:T_i=/data/storage/rrd/ventilatie.rrd:T_intake:AVERAGE LINE1:T_i#ff0000:Invoer"
log(rrdgraph)
result = os.execute(rrdgraph)
