Epiphan recording
I have a customer that want to start and stop recording from a http request, and even feedback.
Got these url from the manager,
Start recording   http://192.168.0.5/admin/channel1/set_params.cgi?publish_enabled=on
Stop recording;  http://192.168.0.5/admin/channel1/set_params.cgi?publish_enabled=off
Feedback that shows if it on or off :    http://192.168.0.5/admin/channel1/get_params.cgi?publish_enabled=on
I want to have a button that turn on/off the recording and a feedback object.
require('socket.http')
socket.http.TIMEOUT = 15
value = event.getvalue()
if value == false then
   socket.http.request('http://192.168.0.5/admin/channel1/set_params.cgi?publish_enabled=off')
else value == true then
   socket.http.request('http://192.168.0.5/admin/channel1/set_params.cgi?publish_enabled=on')
Is is the right way to do it?
How can i get feedback to a 1bit object that shows 1 or 0?
Event script can be simplified a bit:
http = require('socket.http')
param = value and 'on' or 'off'
http.TIMEOUT = 15
http.request('http://192.168.0.5/admin/channel1/set_params.cgi?publish_enabled=' .. param)
You will need a resident script for polling the status (with non-zero sleep time):
http.TIMEOUT = 15
res = http.request('http://192.168.0.5/admin/channel1/get_params.cgi')
log(res)
Post what you get in LM Logs tabs when running this script.
This is what I get when i run the feedback.
* string: <HTML>
<body>
  <h1>Credentials required</h1>
  <p>Username and password are required to access this Epiphan device. Reload the page and try again.</p>
</body>
</HTML>
Now I have the admin and password for the camera. But when I read this page,  https://www.epiphan.com/userguides/pearl...h_http.htm
I'm bit confused where to put the password, in the page they use wget? when they use admin and password to access the camera.
Where do I put the password in the http request?
Try putting credentials into the URL: http://user:password@192.168.0.5/...
Got the same message...
* string: <HTML>
<body>
</body>
</HTML>
Your device might use digest authentication mechanism. Try code from this post: https://forum.logicmachine.net/showthrea...64#pid9364
