SMS not received
We are using a LogicMachine5 Reactor GSM to send SMS in case of alarm of some variables. The script uses a for to send the message to multiple numbers, with a delay between them. You can see the code below (I changed the phone numbers with generic ones for security purposes).
The problem is that not every SMS is received. What could be causing this? Is there any way to check if the SMS is received?
Thank you in advance,
André Neves
require('user.sms')
Nrs_Tlf={'123456789',
       '987654321',
     '147852369'}
tab = string.split(name, ">")
if value==1 then
    Alarme="Alarme:\n"..tab[2].."\n"..timestamp
elseif (value==2) then
   Alarme="Alarme Reconhecido:\n"..tab[2].."\n"..timestamp
elseif (value==3) then
   Alarme="Alarme Reposto:\n"..tab[2].."\n"..timestamp
if (value<4 and value>0) then
    for i = 1, 3, 1 do
      sendsms(Nrs_Tlf[i],Alarme)
      os.sleep(30)
  log("SMS enviados")
  log("Out of bounds.")
See this post on how to add additional logging to the SMS script:
https://forum.logicmachine.net/showthrea...3#pid38043
I've updated the scripts as indicated on the link from @admin but some users are still not receiveing the messages. It's not always the same user, it's random.
In the alerts, the SMS handler indicate that all messages are sent but not all are received.
Please help, the client is using this LM to check high priority alarms and with this behavior is system simply isn't reliable.
Thanks in advance.
André Neves
Restart the SMS script after making changes to the library.
Did a reboot to the LM. There are still some SMS that get lost in the process.
Check that you have replaced AT:read() in the library correctly. When done correctly it will log everything that the modem sends to LM.
Chage AT:read with the version here https://forum.logicmachine.net/showthrea...3#pid38043
when sending SMS the log looks like the 1st image.
In standby, it's always logging 'timeout' as shown in the second image
Update the function once more, it won't spam the log with empty messages.
function AT:read(timeout)
  local char, err, timeout, deftimeout, line
  -- default timeout is 2 seconds, converted to 0.1 sec ticks
  timeout = tonumber(timeout) or 2
  timeout = timeout * 10
  deftimeout = timeout
  -- read until got one line or timeout occured
  while timeout > 0 do
    -- read 1 char
    char, err = self.port:read(1, 0.1)
    -- got data
    if char then
      -- got LF, end of line
      if char == '\n' then
        -- convert to string and empty buffer
        line = table.concat(self.buffer)
        self.buffer = {}
        line = line:trim()
        -- return only lines with data
        if #line > 0 then
          log('read line', line)
          return line
        -- reset timeout
          timeout = deftimeout
      -- ignore CR
      elseif char ~= '\r' then
        table.insert(self.buffer, char)
    -- read timeout
    elseif err == 'timeout' then
      timeout = timeout - 1
    -- other error
      break
  if #line > 0 then
    log('read timeout', line)
  return nil, err
Post your logs when SMS does not reach the recipient.
Users Nº1 and 4 didn't get the SMS.
I think they'tre the ones with +CMS ERROR:665
Log in attach.
Thank's for the quick reply
This error indicates poor network signal quality. Check this thread on how to monitor signal level: https://forum.logicmachine.net/showthrea...2#pid34692
Those scripts only return 'unknown' to the group object. In the log we get +CSQ:15,99 /16,99 so we think this is not a signal quality issue. In five SMS 2 are lost on average.
I don't know if its related, but i'm not able to read objects via SMS. It's not important for this project but I'd like to give it a try.
Is there any way to take the line object to the main function (via return maybe)? My idea was to repeat the send every time we get that '+CMS ERROR: 665'
Log the sending result in the resident script, it should be OK if the message is sent.
local res = modem:sendsms(msg:sub(1, sep - 1), msg:sub(sep + 1))
log(res)
The message can be retried several times like this:
for retry = 1, 5 do
  if res == 'OK' then
    break
    os.sleep(5)
It's strange that it keeps failing some of the messages, but I think this will work with this safety. We hope to avoid the problem.
I've added an alert if all the retrys fail just to let the user know via LM that someone didn't get the text.
Thank you for your assist.
