Contdown script
Hello , i want to add contdown script  with indication of remaining time
Countdown script of what?
(28.07.2025, 12:01)Daniel Wrote: Countdown script of what?
Sorry, timer contdown. For example, there will be field for time input( minutes ), and data in this field should decrease up to zerro
Explain your task in more detail. Does the user specify time to run and some action is executed until the timer stops?
(28.07.2025, 13:09)admin Wrote: Explain your task in more detail. Does the user specify time to run and some action is executed until the timer stops?
Ok.
1.User defines ( inputs ) the time interval ( in minutes) .
2.He pushes button start - the time on the indicator starts to decrease.
3. when the counter reaches zero the output will work
Check this
https://forum.logicmachine.net/showthrea...9#pid11119
