[OLD] LogicMachine firmware 2025.07
LM 2025.07 beta firmware is ready for testing. This version includes many bug fixes and improvements.
Most notable changes:
- Old visualization is disabled for new installations (does not apply if upgrading from anĀ older version or restoring a backup)
- New Visu beta app added
- Added support for new Visu cloud version
- Mosaic app removed
Old visualization and Mosaic can still be used with this firmware. No new features will be added to old visualization and Mosaic. Only critical bug fixes will be provided.
You can find your hardware model in the "Upgrade firmware" window:
[Image: attachment.php?aid=1740]
LM5 Power devices with i.MX6 CPU
LM5 Lite (3 DIN units): image file | signature
LM5 Lite + Ext (4 or 6 DIN units): image file | signature
LM5 Reactor GM KNX: image file | signature
LM5 Reactor GM CANx: image file | signature
LM5 Reactor Dimmer KNX: image file | signature
LM5 Reactor Dimmer CANx: image file | signature
LM5 Reactor IO V2/V3: image file | signature
LM5 Reactor IO V2/V3 + LTE: image file | signature
LM5 M4 (4 DIN units): image file | signature
LM Wall (Ambient V2): image file | signature
Extra packages (i.MX6 CPU)
libmysqlclient has been replaced by libmariadb. No script changes are needed for MySQL/MariaDB connectivity.
(30.07.2025, 10:09)admin Wrote: LM 2025.07 beta firmware is ready for testing. This version includes many bug fixes and improvements.
Thanks admin,
fantastic, a clarification; if I will install new firmware mosaic disappear, but if I will install the ipk it works again, is it? I ask this because until I make the migration I would like use mosaic. Is it possible have the ipk of mosaic?
BR Cristian
Installed app will not disappear. If you do a factory reset then it will be gone but you can install it from the store.
(30.07.2025, 19:03)Daniel Wrote: Installed app will not disappear. If you do a factory reset then it will be gone but you can install it from the store.
Thanks for the answer
What is the latest firmware for the Logic Machine 4? I cannot see it listed here.
LM4 reached end of life status. The last firmware is 2024.04: https://openrb.com/firmwares/
Browser Google Chrome (last update)
HW: LM5 Lite + Ext (i.MX6)
SW: 20250730
The connection to knx is working, KNX Statistic is displayed normally.
The problem of opening the knx interface configuration window
System Config -> Network -> KNX Connection
This is known bug, enable zerotier as a work around.
Hello everyone, is it necessary to install additional packages? The file names give you an idea of what they are. Some might find them confusing; there's a list with descriptions.
Only if you require certain functionality that's is not present by default in the firmware. For example MySQL/MariaDB connectivity or 1-wire connection via USB adapter.
(12.08.2025, 10:01)admin Wrote: Only if you require certain functionality that's is not present by default in the firmware. For example MySQL/MariaDB connectivity or 1-wire connection via USB adapter.
Thanks, admin. Can you also describe the following files?
liblua-mysql_2.2.0-7
libow_3.2p2-1
luable_20240304
luai2c_20170406
luaow_1.0
luaprotobuf_20220613-1
luastruct_1.4
luaxlsxwriter_0.0.6
luazipwriter_0.1.5
luazlib_0.5
owserver_3.2p2-1
Study our Knowledge base, after that all will be clear:
https://kb.logicmachine.net/
(12.08.2025, 12:06)Daniel Wrote: Study our Knowledge base, after that all will be clear:
Thanks, admin.
