trends name
Hello
Is it possible to retrieve the trends names for display in an application?
I would like to create a LogicMachine interface where clients can select trends from a dynamically generated list based on available curves.
THX
Try this
query = 'SELECT name FROM trends'
for _, object in ipairs(db:getall(query)) do
      name=tostring(object.name or '')
      log(name)
(02.09.2025, 14:14)Daniel Wrote: Try this
      log(name)
I try this but i don't have all the trends
local rows = db:getall("SELECT id, name FROM trends ORDER BY name COLLATE NOCASE")
for _, r in ipairs(rows or {}) do
  log(string.format('%s (id=%s)', tostring(r.name or ''), tostring(r.id or '')))
if not rows or #rows == 0 then
  log('[db-trends] Aucun enregistrement trouvé dans la table trends (ou table vide).')
how many trends do you have?
(03.09.2025, 06:56)Daniel Wrote: how many trends do you have?
i have 34 trends
Check the logs in LogicMachine Log tab.
(03.09.2025, 12:43)Daniel Wrote: Check the logs in LogicMachine Log tab.
thx
