24.09.2025, 11:18
Hello Guys,
I have an LM5p2-KC with 20240426 firmware version (LM5 Lite + Ext (i.MX6)) in witch I can't enable RTU 3 Port.
I go to RTU Settings and I check the box that says "RTU 3 - RTU (serial) enabled:" but when I save that settings and I go again to RTU Settings, the box remain unchecked. I have tried several times but it's always happening the same thing.
After that if I try to add a Modbus device in RTU 3 Port I get an error that says "RTU (serial) is not enabled".
I'm attaching some print screens here.
Can you help me with this?
Thank you.
Thank you.
